Seznam chybových kódů
Napsal: 19 lis 2009, 18:26
od radekrat
Sice je to v anglictine, ale snad se to bude nekomu chodit. Tohle je seznam chybovych kodu ze Stila
P0100
Mass or Volume Air Flow Circuit Malfunction
P0101
Mass or Volume Air Flow Circuit Range/Performance Problem
P0102
Mass or Volume Air Flow Circuit Low Input
P0103
Mass or Volume Air Flow Circuit High Input
P0104
Mass or Volume Air Flow Circuit Intermittent
P0105
Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
P0106
Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0107
Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108
Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0109
Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
P0109
Intake Air Temperature Circuit Malfunction
P0110
IAT Circuit Malfunction
P0111
Intake Air Temperature Circuit Range/Performance Problem
P0112
Intake Air Temperature Circuit Low Input
P0113
Intake Air Temperature Circuit High Input
P0114
Intake Air Temperature Circuit Intermittent
P0115
Engine Coolant Temperature Circuit Malfunction
P0116
Engine Coolant Temperature Circuit Range/Performance Problem
P0117
Engine Coolant Temperature Circuit Low Input
P0118
Engine Coolant Temperature Circuit High Input
P0119
Engine Coolant Temperature Circuit Intermittent
P0120
Throttle Position Sensor/Switch A Circuit Malfunction
P0121
Throttle Position Sensor/Switch A Circuit Range/Performance Problem
P0122
Throttle Position Sensor/Switch A Circuit Low Input
P0123
Throttle Position Sensor/Switch A Circuit High Input
P0124
Throttle Position Sensor/Switch A Circuit Intermittent
P0125
Insufficient Coolant Temperature for Closed Loop Fuel Control;
ECT Excessive Time to Closed Loop Fuel Control
P0126
Insufficient Coolant Temperature for Stable Operation
P0128
Coolant Thermostat Malfunction
P0130
O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
P0131
O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
P0132
O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
P0133
O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0134
O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
P0135
O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0136
O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
P0137
O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
P0138
O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
P0139
O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0140
O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
P0141
O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0142
O2 Sensor Circuit Malfunction (Bank 1 Sensor 3)
P0143
O2 Sensor Circuit Low Voltage (Bank 1 Sensor 3)
P0144
O2 Sensor Circuit High Voltage (Bank 1 Sensor 3)
P0145
O2 Sensor Circuit Slow Response (Bank 1 Sensor 3)
P0146
O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3)
P0147
O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)
P0150
O2 Sensor Circuit Malfunction (Bank 2 Sensor 1)
P0151
O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
P0152
O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
P0153
O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0154
O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
P0155
O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0156
O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0157
O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
P0158
O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
P0159
O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0160
O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
P0161
O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P0162
O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
P0163
O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
P0164
O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
P0165
O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
P0166
O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
P0167
O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
P0170
Fuel Trim Malfunction (Bank 1)
P0171
Fuel Trim System Lean (Bank 1)
P0172
Fuel Trim too Rich (Bank 1)
P0173
Fuel Trim Malfunction (Bank 2)
P0174
Fuel Trim too Lean (Bank 2)
P0175
Fuel Trim too Rich (Bank 2)
P0176
Fuel Composition Sensor Circuit Malfunction
P0177
Fuel Composition Sensor Circuit Range/Performance
P0178
Fuel Composition Sensor Circuit Low Input
P0179
Fuel Composition Sensor Circuit High Input
P0180
Fuel Temperature Sensor A Circuit Malfunction
P0181
Fuel Temperature Sensor A Circuit Range/Performance
P0182
Fuel Temperature Sensor A Circuit Low Input
P0183
Fuel Temperature Sensor A Circuit High Input
P0184
Fuel Temperature Sensor A Circuit Intermittent
P0185
Fuel Temperature Sensor B Circuit Malfunction
P0186
Fuel Temperature Sensor B Circuit Range/Performance
P0187
Fuel Temperature Sensor B Circuit Low Input
P0188
Fuel Temperature Sensor B Circuit High Input
P0189
Fuel Temperature Sensor B Circuit Intermittent
P0190
Fuel Rail Pressure Sensor Circuit Malfunction
P0191
Fuel Rail Pressure Sensor Circuit Range/Performance
P0192
Fuel Rail Pressure Sensor Circuit Low Input
P0193
Fuel Rail Pressure Sensor Circuit High Input
P0194
Fuel Rail Pressure Sensor Circuit Intermittent
P0195
Engine Oil Temperature Sensor Malfunction
P0196
Engine Oil Temperature Sensor Range/Performance
P0197
Engine Oil Temperature Sensor Low
P0198
Engine Oil Temperature Sensor High
P0199
Engine Oil Temperature Sensor Intermittent
P0200
Injector Circuit Malfunction
P0201
Injector Circuit Malfunction - Cylinder 1
P0202
Injector Circuit Malfunction - Cylinder 2
P0203
Injector Circuit Malfunction - Cylinder 3
P0204
Injector Circuit Malfunction - Cylinder 4
P0205
Injector Circuit Malfunction - Cylinder 5
P0206
Injector Circuit Malfunction - Cylinder 6
P0207
Injector Circuit Malfunction - Cylinder 7
P0208
Injector Circuit Malfunction - Cylinder 8
P0209
Injector Circuit Malfunction - Cylinder 9
P0210
Injector Circuit Malfunction - Cylinder 10
P0211
Injector Circuit Malfunction - Cylinder 11
P0212
Injector Circuit Malfunction - Cylinder 12
P0213
Cold Start Injector 1 Malfunction
P0214
Cold Start Injector 2 Malfunction
P0215
Engine Shutoff Solenoid Malfunction
P0216
Injection Timing Control Circuit Malfunction
P0217
Engine Overtemp Condition
P0218
Transmission Over Temperature Condition
P0219
Engine Overspeed Condition
P0220
Throttle/Petal Position Sensor/Switch B Circuit Malfunction
P0221
Throttle/Petal Position Sensor/Switch B Circuit Range/Performance Problem
P0222
Throttle/Petal Position Sensor/Switch B Circuit Low Input
P0223
Throttle/Petal Position Sensor/Switch B Circuit High Input
P0224
Throttle/Petal Position Sensor/Switch B Circuit Intermittent
P0225
Throttle/Petal Position Sensor/Switch C Circuit Malfunction
P0226
Throttle/Petal Position Sensor/Switch C Circuit Range/Performance Problem
P0227
Throttle/Petal Position Sensor/Switch C Circuit Low Input
P0228
Throttle/Petal Position Sensor/Switch C Circuit High Input
P0229
Throttle/Petal Position Sensor/Switch C Circuit Intermittent
P0230
Fuel Pump Primary Circuit Malfunction
P0231
Fuel Pump Secondary Circuit Low
P0232
Fuel Pump Secondary Circuit High
P0233
Fuel Pump Secondary Circuit Intermittent
P0234
Engine Overboost Condition
P0235
Turbocharger Boost Sensor A Circuit Malfunction
P0236
Turbocharger Boost Sensor A Circuit Range/Performance
P0237
Turbocharger Boost Sensor A Circuit Low
P0238
Turbocharger Boost Sensor A Circuit High
P0239
Turbocharger Boost Sensor B Malfunction
P0240
Turbocharger Boost Sensor B Circuit Range/Performance
P0241
Turbocharger Boost Sensor B Circuit Low
P0242
Turbocharger Boost Sensor B Circuit High
P0243
Turbocharger Wastegate Solenoid A Malfunction
P0244
Turbocharger Wastegate Solenoid A Range/Performance
P0245
Turbocharger Wastegate Solenoid A Low
P0246
Turbocharger Wastegate Solenoid A High
P0247
Turbocharger Wastegate Solenoid B Malfunction
P0248
Turbocharger Wastegate Solenoid B Range/Performance
P0249
Turbocharger Wastegate Solenoid B Low
P0250
Turbocharger Wastegate Solenoid B High
P0251
Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
P0252
Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
P0253
Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
P0254
Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
P0255
Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
P0256
Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
P0257
Injection Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector)
P0258
Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector)
P0259
Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector)
P0260
Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector)
P0261
Cylinder 1 Injector Circuit Low
P0262
Cylinder 1 Injector Circuit High
P0263
Cylinder 1 Contribution/Balance Fault
P0264
Cylinder 2 Injector Circuit Low
P0265
Cylinder 2 Injector Circuit High
P0266
Cylinder 2 Contribution/Balance Fault
P0267
Cylinder 3 Injector Circuit Low
P0268
Cylinder 3 Injector Circuit High
P0269
Cylinder 3 Contribution/Balance Fault
P0270
Cylinder 4 Injector Circuit Low
P0271
Cylinder 4 Injector Circuit High
P0272
Cylinder 4 Contribution/Balance Fault
P0273
Cylinder 5 Injector Circuit Low
P0274
Cylinder 5 Injector Circuit High
P0275
Cylinder 5 Contribution/Balance Fault
P0276
Cylinder 6 Injector Circuit Low
P0277
Cylinder 6 Injector Circuit High
P0278
Cylinder 6 Contribution/Balance Fault
P0279
Cylinder 7 Injector Circuit Low
P0280
Cylinder 7 Injector Circuit High
P0281
Cylinder 7 Contribution/Balance Fault
P0282
Cylinder 8 Injector Circuit Low
P0283
Cylinder 8 Injector Circuit High
P0284
Cylinder 8 Contribution/Balance Fault
P0285
Cylinder 9 Injector Circuit Low
P0286
Cylinder 9 Injector Circuit High
P0287
Cylinder 9 Contribution/Balance Fault
P0288
Cylinder 10 Injector Circuit Low
P0289
Cylinder 10 Injector Circuit High
P0290
Cylinder 10 Contribution/Balance Fault
P0291
Cylinder 11 Injector Circuit Low
P0292
Cylinder 11 Injector Circuit High
P0293
Cylinder 11 Contribution/Balance Fault
P0294
Cylinder 12 Injector Circuit Low
P0295
Cylinder 12 Injector Circuit High
P0296
Cylinder 12 Contribution/Range Fault
P0300
Random/Multiple Cylinder Misfire Detected
P0301
Cylinder 1 Misfire Detected
P0302
Cylinder 2 Misfire Detected
P0303
Cylinder 3 Misfire Detected
P0304
Cylinder 4 Misfire Detected
P0305
Cylinder 5 Misfire Detected
P0306
Cylinder 6 Misfire Detected
P0307
Cylinder 7 Misfire Detected
P0308
Cylinder 8 Misfire Detected
P0309
Cylinder 9 Misfire Detected
P0310
Cylinder 10 Misfire Detected
P0311
Cylinder 11 Misfire Detected
P0312
Cylinder 12 Misfire Detected
P0320
Ignition/Distributor Engine Speed Input Circuit Malfunction
P0321
Ignition/Distributor Engine Speed Input Circuit Range/Performance
P0322
Ignition/Distributor Engine Speed Input Circuit No Signal
P0323
Ignition/Distributor Engine Speed Input Circuit Intermittent
P0325
Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor)
P0326
Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
P0327
Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)
P0328
Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
P0329
Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)
P0330
Knock Sensor 2 Circuit Malfunction (Bank 2)
P0331
Knock Sensor 2 Circuit Range/Performance (Bank 2)
P0332
Knock Sensor 2 Circuit Low Input (Bank 2)
P0333
Knock Sensor 2 Circuit High Input (Bank 2)
P0334
Knock Sensor 2 Circuit Intermittent (Bank 2)
P0335
Crankshaft Position Sensor A Circuit Malfunction
P0336
Crankshaft Position Sensor A Circuit Range/Performance
P0337
Crankshaft Position Sensor A Circuit Low Input
P0338
Crankshaft Position Sensor A Circuit High Input
P0339
Crankshaft Position Sensor A Circuit Intermittent
P0340
Camshaft Position Sensor Circuit Malfunction
P0341
Camshaft Position Sensor Circuit Range/Performance
P0342
Camshaft Position Sensor Circuit Low Input
P0343
Camshaft Position Sensor Circuit High Input
P0344
Camshaft Position Sensor Circuit Intermittent
P0350
Ignition Coil Primary/Secondary Circuit Malfunction
P0351
Ignition Coil A Primary/Secondary Circuit Malfunction
P0352
Ignition Coil B Primary/Secondary Circuit Malfunction
P0353
Ignition Coil C Primary/Secondary Circuit Malfunction
P0354
Ignition Coil D Primary/Secondary Circuit Malfunction
P0355
Ignition Coil E Primary/Secondary Circuit Malfunction
P0356
Ignition Coil F Primary/Secondary Circuit Malfunction
P0357
Ignition Coil G Primary/Secondary Circuit Malfunction
P0358
Ignition Coil H Primary/Secondary Circuit Malfunction
P0359
Ignition Coil I Primary/Secondary Circuit Malfunction
P0360
Ignition Coil J Primary/Secondary Circuit Malfunction
P0361
Ignition Coil K Primary/Secondary Circuit Malfunction
P0362
Ignition Coil L Primary/Secondary Circuit Malfunction
P0370
Timing Reference High Resolution Signal A Malfunction
P0371
Timing Reference High Resolution Signal A Too Many Pulses
P0372
Timing Reference High Resolution Signal A Too Few Pulses
P0373
Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
P0374
Timing Reference High Resolution Signal A No Pulses
P0375
Timing Reference High Resolution Signal B Malfunction
P0376
Timing Reference High Resolution Signal B Too Many Pulses
P0377
Timing Reference High Resolution Signal B Too Few Pulses
P0378
Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
P0379
Timing Reference High Resolution Signal B No Pulses
P0380
Glow Plug/Heater Circuit "A" Malfunction
P0381
Glow Plug/Heater Indicator Circuit Malfunction
P0382
Exhaust Gas Recirculation Flow Malfunction
P0385
Crankshaft Position Sensor B Circuit Malfunction
P0386
Crankshaft Position Sensor B Circuit Range/Performance
P0387
Crankshaft Position Sensor B Circuit Low Input
P0388
Crankshaft Position Sensor B Circuit High Input
P0389
Crankshaft Position Sensor B Circuit Intermittent
P0400
P0401
Exhaust Gas Recirculation Flow Insufficient Detected
P0402
Exhaust Gas Recirculation Flow Excessive Detected
P0403
Exhaust Gas Recirculation Circuit Malfunction
P0404
Exhaust Gas Recirculation Circuit Range/Performance
P0405
Exhaust Gas Recirculation Sensor A Circuit Low
P0406
Exhaust Gas Recirculation Sensor A Circuit High
P0407
Exhaust Gas Recirculation Sensor B Circuit Low
P0408
Exhaust Gas Recirculation Sensor B Circuit High
P0410
Secondary Air Injection System Malfunction
P0411
Secondary Air Injection System Incorrect Flow Detected
P0412
Secondary Air Injection System Switching Valve A Circuit Malfunction
P0413
Secondary Air Injection System Switching Valve A Circuit Open
P0414
Secondary Air Injection System Switching Valve A Circuit Shorted
P0415
Secondary Air Injection System Switching Valve B Circuit Malfunction
P0416
Secondary Air Injection System Switching Valve B Circuit Open
P0417
Secondary Air Injection System Switching Valve B Circuit Shorted
P0418
Secondary Air Injection System Relay "A" Circuit Malfunction
P0419
Secondary Air Injection System Relay "B" Circuit Malfunction
P0420
Catalyst System Efficiency Below Threshold (Bank 1)
P0421
Warm Up Catalyst Efficiency Below Threshold (Bank 1)
P0422
Main Catalyst Efficiency Below Threshold (Bank 1)
P0423
Heated Catalyst Efficiency Below Threshold (Bank 1)
P0424
Heated Catalyst Temperature Below Threshold (Bank 1)
P0426
Catalyst Temperature Sensor Range/Performance (Bank 1)
P0427
Catalyst Temperature Sensor Low Input (Bank 1)
P0428
Catalyst Temperature Sensor High Input (Bank 1)
P0430
Catalyst System Efficiency Below Threshold (Bank 2)
P0431
Warm Up Catalyst Efficiency Below Threshold (Bank 2)
P0432
Main Catalyst Efficiency Below Threshold (Bank 2)
P0433
Heated Catalyst Efficiency Below Threshold (Bank 2)
P0434
Heated Catalyst Temperature Below Threshold (Bank 2)
P0436
Catalyst Temperature Sensor Range/Performance (Bank 2)
P0437
Catalyst Temperature Sensor Low Input (Bank 2)
P0438
Catalyst Temperature Sensor High Input (Bank 2)
P0440
Evaporative Emission Control System Malfunction
P0441
Evaporative Emission Control System Incorrect Purge Flow
P0442
Evaporative Emission Control System Leak Detected (small leak)
P0443
Evaporative Emission Control System Purge Control Valve Circuit Malfunction
P0444
Evaporative Emission Control System Purge Control Valve Circuit Open
P0445
Evaporative Emission Control System Purge Control Valve Circuit Shorted
P0446
Evaporative Emission Control System Vent Control Circuit Malfunction
P0447
Evaporative Emission Control System Vent Control Circuit Open
P0448
Evaporative Emission Control System Vent Control Circuit Shorted
P0449
Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
P0450
Evaporative Emission Control System Pressure Sensor Malfunction
P0451
Evaporative Emission Control System Pressure Sensor Range/Performance
P0452
Evaporative Emission Control System Pressure Sensor Low Input
P0453
Evaporative Emission Control System Pressure Sensor High Input
P0454
Evaporative Emission Control System Pressure Sensor Intermittent
P0455
Evaporative Emission Control System Leak Detected (gross leak)
P0460
Fuel Level Sensor Circuit Malfunction
P0461
Fuel Level Sensor Circuit Range/Performance
P0462
Fuel Level Sensor Circuit Low Input
P0463
Fuel Level Sensor Circuit High Input
P0464
Fuel Level Sensor Circuit Intermittent
P0465
Purge Flow Sensor Circuit Malfunction
P0466
Purge Flow Sensor Circuit Range/Performance
P0467
Purge Flow Sensor Circuit Low Input
P0468
Purge Flow Sensor Circuit High Input
P0469
Purge Flow Sensor Circuit Intermittent
P0470
Exhaust Pressure Sensor Malfunction
P0471
Exhaust Pressure Sensor Range/Performance
P0472
Exhaust Pressure Sensor Low
P0473
Exhaust Pressure Sensor High
P0474
Exhaust Pressure Sensor Intermittent
P0475
Exhaust Pressure Control Valve Malfunction
P0476
Exhaust Pressure Control Valve Range/Performance
P0477
Exhaust Pressure Control Valve Low
P0478
Exhaust Pressure Control Valve High
P0479
Exhaust Pressure Control Valve Intermittent
P0480
Cooling Fan 1 Control Circuit Malfunction
P0481
Cooling Fan 2 Control Circuit Malfunction
P0482
Cooling Fan 3 Control Circuit Malfunction
P0483
Cooling Fan Rationality Check Malfunction
P0484
Cooling Fan Circuit Over Current
P0485
Cooling Fan Power/Ground Circuit Malfunction
P0500
Vehicle Speed Sensor Malfunction
P0501
Vehicle Speed Sensor Range/Performance
P0502
Vehicle Speed Sensor Low Input
P0503
Vehicle Speed Sensor Intermittent/Erratic/High
P0505
Idle Control System Malfunction
P0506
Idle Control System RPM Lower Than Expected
P0507
Idle Control System RPM Higher Than Expected
P0510
Closed Throttle Position Switch Malfunction
P0520
Engine Oil Pressure Sensor/Switch Circuit Malfunction
P0521
Engine Oil Pressure Sensor/Switch Circuit Range/Performance
P0522
Engine Oil Pressure Sensor/Switch Circuit Low Voltage
P0523
Engine Oil Pressure Sensor/Switch Circuit High Voltage
P0530
A/C Refrigerant Pressure Sensor Circuit Malfunction
P0531
A/C Refrigerant Pressure Sensor Circuit Range/Performance
P0532
A/C Refrigerant Pressure Sensor Circuit Low Input
P0533
A/C Refrigerant Pressure Sensor Circuit High Input
P0534
Air Conditioner Refrigerant Charge Loss
P0550
Power Steering Pressure Sensor Circuit Malfunction
P0551
Power Steering Pressure Sensor Circuit Range/Performance
P0552
Power Steering Pressure Sensor Circuit Low Input
P0553
Power Steering Pressure Sensor Circuit High Input
P0554
Power Steering Pressure Sensor Circuit Intermittent
P0560
System Voltage Malfunction
P0561
System Voltage Unstable
P0562
System Voltage Low
P0562
A/C pressure sensor low voltage(Chrysler)
P0563
System Voltage High
P0565
Cruise Control On Signal Malfunction
P0566
Cruise Control Off Signal Malfunction
P0567
Cruise Control Resume Signal Malfunction
P0568
Cruise Control Set Signal Malfunction
P0569
Cruise Control Coast Signal Malfunction
P0570
Cruise Control Accel Signal Malfunction
P0571
Cruise Control/Brake Switch A Circuit Malfunction
P0572
Cruise Control/Brake Switch A Circuit Low
P0573
Cruise Control/Brake Switch A Circuit High
P0574
Cruise Control Related Malfunction
P0575
P0576
P0576
P0578
P0579
P0580
P0600
Serial Communication Link Malfunction
P0601
Control Module Read Only Memory(ROM)
P0602
Control Module Programming Error
P0603
Internal Control Module Keep Alive Memory (KAM) Error
P0604
Internal Control Module Random Access Memory (RAM) Error
P0605
Internal Control Module Read Only Memory (ROM) Error
P0606
PCM Processor Fault
P0608
Control Module VSS Output "A" Malfunction
P0609
Control Module VSS Output "B" Malfunction
P0620
Generator Control Circuit Malfunction
P0621
Generator Lamp "L" Control Circuit Malfunction
P0622
Generator Field "F" Control Circuit Malfunction
P0650
Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
P0654
Engine RPM Output Circuit Malfunction
P0655
Engine Hot Lamp Output Control Circuit Malfucntion
P0656
Fuel Level Output Circuit Malfunction
P0700
Transmission Control System Malfunction
P0701
Transmission Control System Range/Performance
P0702
Transmission Control System Electrical
P0703
Torque Converter/Brake Switch B Circuit Malfunction
P0704
Clutch Switch Input Circuit Malfunction
P0705
Transmission Range Sensor Circuit malfunction (PRNDL Input)
P0706
Transmission Range Sensor Circuit Range/Performance
P0707
Transmission Range Sensor Circuit Low Input
P0708
Transmission Range Sensor Circuit High Input
P0709
Transmission Range Sensor Circuit Intermittent
P0710
Transmission Fluid Temperature Sensor Circuit Malfunction
P0711
Transmission Fluid Temperature Sensor Circuit Range/Performance
P0712
Transmission Fluid Temperature Sensor Circuit Low Input
P0713
Transmission Fluid Temperature Sensor Circuit High Input
P0714
Transmission Fluid Temperature Sensor Circuit Intermittent
P0715
Input/Turbine Speed Sensor Circuit Malfunction
P0716
Input/Turbine Speed Sensor Circuit Range/Performance
P0717
Input/Turbine Speed Sensor Circuit No Signal
P0718
Input/Turbine Speed Sensor Circuit Intermittent
P0719
Torque Converter/Brake Switch B Circuit Low
P0720
Output Speed Sensor Circuit Malfunction
P0721
Output Speed Sensor Range/Performance
P0722
Output Speed Sensor No Signal
P0723
Output Speed Sensor Intermittent
P0724
Torque Converter/Brake Switch B Circuit High
P0725
Engine Speed input Circuit Malfunction
P0726
P0727
P0728
P0730
Incorrect Gear Ratio
P0731
Gear 1 Incorrect ratio
P0732
Gear 2 Incorrect ratio
P0733
Gear 3 Incorrect ratio
P0734
Gear 4 Incorrect ratio
P0735
Gear 5 Incorrect ratio
P0736
Reverse incorrect gear ratio
P0740
Torque Converter Clutch Circuit Malfuction
P0741
Torque Converter Clutch Circuit Performance or Stuck Off
P0742
Torque Converter Clutch Circuit Stuck On
P0743
Torque Converter Clutch Circuit Electrical
P0744
Torque Converter Clutch Circuit Intermittent
P0745
Pressure Control Solenoid Malfunction
P0746
Pressure Control Solenoid Performance or Stuck Off
P0747
Pressure Control Solenoid Stuck On
P0748
Pressure Control Solenoid Electrical
P0749
Pressure Control Solenoid Intermittent
P0750
Shift Solenoid A Malfunction
P0751
Shift Solenoid A Performance or Stuck Off/
1-2 Shift Solenoid Valve Performance
P0752
Shift Solenoid A Stuck On
P0753
Shift Solenoid A Electrical/
1-2 Shift Solenoid Circuit Electrical
P0754
Shift Solenoid A Intermittent
P0755
Shift Solenoid B Malfunction
P0756
Shift Solenoid B Performance or Stuck Off/
2-3 Shift Solenoid Valve Performance
P0757
Shift Solenoid B Stuck On
P0758
Shift Solenoid B Electrical/ 2-3 Shift Solenoid Circuit Electrical
P0759
Shift Solenoid B Intermittent
P0760
Shift Solenoid C Malfunction
P0761
Shift Solenoid C Performance or Stuck Off
P0762
Shift Solenoid C Stuck On
P0763
Shift Solenoid C Electrical
P0764
Shift Solenoid C Intermittent
P0765
Shift Solenoid D Malfunction
P0766
Shift Solenoid D Performance or Stuck Off
P0767
Shift Solenoid D Stuck On
P0768
Shift Solenoid D Electrical
P0769
Shift Solenoid D Intermittent
P0770
Shift Solenoid E Malfunction
P0771
Shift Solenoid E Performance or Stuck Off
P0772
Shift Solenoid E Stuck On
P0773
Shift Solenoid E Electrical
P0774
Shift Solenoid E Intermittent
P0775
Pressure Control Solenoid B Malfunction
P0776
Pressure Control Solenoid B Performance
P0777
Pressure Control Solenoid B Stuck On
P0778
Pressure Control Solenoid B Electrical
P0779
Pressure Control Solenoid B Intermittent
P0780
Shift Malfunction
P0781
1-2 Shift Malfunction
P0782
2-3 Shift Malfunction
P0783
3-4 Shift Malfunction
P0784
4-5 Shift Malfunction
P0785
Shift/Timing Solenoid Malfunction/ 3-2 Shift Solenoid Circuit Electrical
P0786
Shift/Timing Solenoid Range/Performance
P0787
Shift/Timing Solenoid Low
P0788
Shift/Timing Solenoid High
P0789
Shift/Timing Solenoid Intermittent
P0790
Normal/Performance Switch Circuit Malfunction
P0801
Reverse Inhibit Control Circuit Malfunction
P0803
1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
P0804
1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
P1100
MAF Sensor Intermittent/ Check of all OBDII Systems Not Complete
P1101
MAF Sensor Out Of Self Test Range./
KOER Not Able To Complete KOER Aborted
P1102
MAF Sensor In Range But Lower Than Expected
P1103
MAF Sensor In Range But Higher Than Expected
P1104
MAF Ground Malfunction
P1105
Dual Alternator Upper Fault
P1106
Dual Alternator Lower Fault/ Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage
P1107
Dual Alternator Lower Circuit Malfunction/ Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage
P1108
Dual Alternator Battery Lamp Circuit Malfunction
P1109
IAT - B Sensor Intermittent
P1110
IAT Sensor (D/C) Open/Short
P1111
Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
P1112
Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage
P1113
IAT Sensor Open/Short
P1114
Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage/IAT - B Circuit Low Input
P1115
Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage/IAT - B Circuit High Input
P1116
Engine Coolant sensor out of range/ECT Sensor Out Of Self Test Range
P1117
Engine Coolant Sensor intermittent/ECT Sensor Intermittent
P1118
Manifold Absolute Temperature Circuit Low Input
P1119
Manifold Absolute Temperature Circuit High Input
P1120
Throttle position sensor out of range
P1121
Throttle Position (TP) Sensor Circuit Intermittent High Voltage
P1122
Throttle Position (TP) Sensor Circuit Intermittent Low Voltage
P1123
Throttle Position Sensor In Range But Higher Than Expected
P1124
Throttle Position Sensor Out Of Self Test Range
P1125
Throttle position sensor intermittent
P1126
Throttle Position (Narrow Range) Sensor Circuit Malfunction
P1127
Exhaust Not Warm, Downstream O2 Sensor
P1128
Upstream Heated O2 Sensors Swapped
P1129
Downstream Heated O2 Sensors Swapped
P1130
Lack Of HO2S Switch - Adaptive Fuel At Limit
P1131
Lack Of HO2S Switch - Sensor Indicates Lean
P1132
Lack Of HO2S Switch - Sensor Indicates Rich
P1133
HO2S Insufficient Switching Sensor 1
P1134
HO2S Transition Time Ratio Sensor 1
P1135
Pedal Position Sensor A Circuit Intermittent
P1136
Fan Control Circuit Malfunction
P1137
P1138
Lack Of HO2S12 Switch - Sensor Indicates Rich
P1139
Water In Fuel Indicator Circuit Malfunction
P1140
Water In Fuel Condition
P1141
Fuel Restriction Indicator Circuit Malfunction
P1142
Fuel Restriction Condition
P1143
Air Assist Control Valve Range/Performance
P1144
Air Assist Control Valve Circuit Malfunction
P1150
Lack Of HO2S21 Switch - Adaptive Fuel At Limit
P1151
Lack Of HO2S21 Switch - Sensor Indicates Lean
P1152
Lack Of HO2S21 Switch - Sensor Indicates Rich
P1153
Bank 2 Fuel Control Shifted Lean
P1154
Bank 2 Fuel Control Shifted Rich
P1155
Alternative Fuel Controller
P1156
Fuel Select Switch Malfunction
P1157
Lack Of HO2S22 Switch - Sensor Indicates Lean
P1158
Lack Of HO2S22 Switch - Sensor Indicates Rich
P1159
Fuel Stepper Motor Malfunction
P1167
Invalid Test,throttle not depressed
P1168
Fuel Rail Sensor In-Range Low Failure
P1169
Fuel Rail Sensor In-Range High Failure
P1170
ESO - Engine Shut Off Solenoid Fault
P1171
Rotor Sensor Fault
P1172
Rotor Control Fault
P1173
Rotor Calibration Fault
P1174
Cam Sensor Fault
P1175
Cam Control Fault
P1176
Cam Calibration Fault
P1177
Synchronization Fault
P1178
( open )
P1180
Fuel Delivery System Malfunction - Low
P1181
Fuel Delivery System Malfunction - High
P1182
Fuel Shut Off Solenoid Malfunction
P1183
Engine Oil Temperature Circuit Malfunction
P1184
Engine Oil Temperature Out Of Self Test Range
P1185
FTS High - Fuel Pump Temperature Sensor High
P1186
FTS Low - Fuel Pump Temperature Sensor Low
P1187
Variant Selection
P1188
Calibration Memory Fault
P1189
Pump Speed Signal Fault
P1190
Calibration Resistor Out Of Range
P1191
Key Line Voltage
P1192
Voltage External
P1193
EGR Drive Overcurrent
P1194
ECU A/D Converter
P1195
SCP HBCC Failed To Initialize
P1196
Key Off Voltage High
P1197
Key Off Voltage Low
P1198
Pump Rotor Control Underfueling
P1199
Fuel Level Input Circuit Low
P1200
Injector Control Circuit
P1201
Injector Circuit Open / Shorted - Cylinder #1
P1202
Injector Circuit Open / Shorted - Cylinder #2
P1203
Injector Circuit Open / Shorted - Cylinder #3
P1204
Injector Circuit Open / Shorted - Cylinder #4
P1205
Injector Circuit Open / Shorted - Cylinder #5
P1206
Injector Circuit Open / Shorted - Cylinder #6
P1209
Injector Control Pressure System Fault
P1210
Injector Control Pressure Above Expected Level
P1211
Injector Control Pressure Sensor Above / Below Desired
P1212
Injector Control Pressure Not Detected During Crank
P1213
Start Injector Circuit Malfunction
P1214
Pedal Position Sensor B Circuit Intermittent
P1215
Pedal Position Sensor C Circuit Low Input
P1216
Pedal Position Sensor C Circuit High Input
P1217
Pedal Position Sensor C Circuit Intermittent
P1218
CID High
P1219
CID Low
P1220
Series Throttle Control System Malfunction
P1221
Traction Control System Malfunction
P1222
Traction Control Output Circuit Malfunction
P1223
Pedal Demand Sensor B Circuit High Input
P1224
Throttle Position Sensor B Out Of Self Test Range
P1225
Needle Lift Sensor Malfunction
P1226
Control Sleeve Sensor Malfunction
P1227
Wastegate Failed Closed (Over Pressure)
P1228
Wastegate Failed Open (Under Pressure)
P1229
Intercooler Pump Driver Fault
P1230
Fuel Pump Low Speed Malfunction
P1231
Fuel Pump Secondary Circuit Low, High Speed
P1232
Fuel Pump Speed Primary Circuit Malfunction
P1233
Fuel Pump Driver Module Off Line
P1234
P1235
Fuel Pump Control Out Of Range
P1236
P1237
Fuel Pump Secondary Circuit Malfunction
P1238
P1239
Speed Fuel Pump Positive Feed Fault
P1240
Sensor Power Supply Malfunction
P1241
Sensor Power Supply Low Input
P1242
Sensor Power Supply High Input
P1243
Second Fuel Pump Faulty or Ground Fault
P1244
Alternator Load Input Failed High
P1245
Alternator Load Input Failed Low
P1246
P1247
Turbo Boost Pressure Low
P1248
Turbo Boost Pressure Not Detected
P1249
Wastegate Control Valve Performance
P1250
PRC Solenoid Circuit Malfunction
P1251
Air Mixture Solenoid Circuit Malfunction
P1252
Pedal Correlation PDS1 and LPDS High
P1253
Pedal Correlation PDS1 and LPDS Low
P1254
Pedal Correlation PDS2 and LPDS High
P1255
Pedal Correlation PDS2 and LPDS Low
P1256
Pedal Correlation PDS1 and HPDS
P1257
Pedal Correlation PDS2 and HPDS
P1258
Pedal Correlation PDS1 and PDS2
P1259
Immobilizer to PCM Signal Error
P1260
THEFT Detected, Vehicle Immobilzed
P1261
Cylinder #1 High To Low Side Short
P1262
Cylinder #2 High To Low Side Short
P1263
Cylinder #3 High To Low Side Short
P1264
Cylinder #4 High To Low Side Short
P1265
Cylinder #5 High To Low Side Short
P1266
Cylinder #6 High To Low Side Short
P1267
Cylinder #7 High To Low Side Short
P1268
Cylinder #8 High To Low Side Short
P1269
Immobilizer Code Not Programmed
P1270
Engine RPM Or Speed Limiter Reached
P1271
Cylinder #1 High To Low Side Open
P1272
Cylinder #2 High To Low Side Open
P1273
Cylinder #3 High To Low Side Open
P1274
Cylinder #4 High To Low Side Open
P1275
Cylinder #5 High To Low Side Open
P1276
Cylinder #6 High To Low Side Open
P1277
Cylinder #7 High To Low Side Open
P1278
Cylinder #8 High To Low Side Open
P1280
Injection Control Pressure Out Of Range Low
P1281
Injection Control Pressure Out Of Range High
P1282
Excessive Injection Control Pressure
P1283
IPR Circuit Failure
P1284
Aborted KOER - ICP Failure
P1285
Cylinder head over temp sensed
P1286
Fuel Pulse In Range But Lower Than Expected
P1287
Fuel Pulse In Range But Higher Than Expected
P1288
Cylinder Head Temp Sensor Out Of Self Test Range
P1289
Cylinder Head Temp Sensor High Input
P1290
Cylinder Head Temp Sensor Low Input
P1291
Injector High Side Short To GND Or VBATT - Bank 1
P1292
Injector High Side Short To GND Or VBATT - Bank 2
P1293
Injector High Side Open - Bank 1
P1294
Injector High Side Open - Bank 2/Target idle not reached
P1295
Multi-faults - Bank 1 - With Low Side Shorts
P1296
Multi-faults - Bank 2 - With Low Side Shorts
P1297
Injector High Sides Shorted Together
P1298
IDM Failure
P1299
Cylinder Head Overtemperature Protection Active
P1300
Boost Calibration Fault
P1301
Boost Calibration High
P1302
Boost Calibration Low
P1303
EGR Calibration Fault
P1304
EGR Calibration High
P1305
EGR Calibration Low
P1306
Kickdown Relay Pull - In Circuit Fault
P1307
Kickdown Relay Hold Circuit Fault
P1308
A/C Clutch Circuit Fault
P1309
Misfire Monitor AICE Chip Fault
P1313
Misfire Rate Catalyst Damage Fault - Bank 1
P1314
Misfire Rate Catalyst Damage Fault - Bank 2
P1315
Persistent Misfire
P1316
Injector Circuit / IDM Codes Detected
P1317
Injector Circuit / IDM Codes Not Updated
P1336
Crank / Cam Sensor Range / Performance
P1340
Camshaft Position Sensor B Circuit Malfunction
P1341
Camshaft Position Sensor B Range / Performance
P1345
SGC (Cam Position) Sensor Circuit Malfunction/ Crankshaft Position - Camshaft Position Correlation
P1346
Fuel Level Sensor B Circuit Malfunction
P1347
Fuel Level Sensor B Range / Performance
P1348
Fuel Level Sensor B Circuit Low
P1349
Fuel Level Sensor B Circuit High
P1350
Fuel Level Sensor B Intermittent/Bypass Line Monitor
P1351
IDM Input Circuit Malfunction/ Ignition Coil Control Circuit High Voltage
P1352
Ignition Coil A Primary Circuit Malfunction
P1353
Ignition Coil B Primary Circuit Malfunction
P1354
Ignition Coil C Primary Circuit Malfunction
P1355
Ignition Coil D Primary Circuit Malfunction
P1360
Ignition Coil A Secondary Circuit Malfunction
P1361
Ignition Control (IC) Circuit Low Voltage
P1362
Ignition Coil C Secondary Circuit Malfunction
P1363
Ignition Coil D Secondary Circuit Malfunction
P1364
Ignition Coil Primary Circuit Failure
P1365
Ignition Coil Secondary Circuit Failure
P1366
Ignition Spare
P1367
Ignition Spare
P1368
Ignition Spare
P1369
Engine Temperature Light Monitor Failure
P1370
Insufficient RMP Increase During Spark Test
P1371
Ignition Coil - Cylinder 1 - Early Activation Fault
P1372
Ignition Coil - Cylinder 2 - Early Activation Fault
P1373
Ignition Coil - Cylinder 3 - Early Activation Fault
P1374
Crankshaft Position (CKP)/Ignition Coil - Cylinder 4 - Early Activation Fault
P1375
Ignition Coil - Cylinder 5 - Early Activation Fault
P1376
Ignition Coil - Cylinder 6 - Early Activation Fault
P1380
Misfire Detected - Rough Road Data Not Available
P1381
Variable Cam Timing Overadvanced (Bank #1)/ Misfire Detected - No Communication with BCM
P1382
Variable Cam Timing Solenoid #1 Circuit Malfunction
P1383
Variable Cam Timing Overretarded (Bank #1)
P1384
VVT Solenoid A Malfunction
P1385
Variable Cam Timing Solenoid B Malfunction
P1386
Variable Cam Timing Overadvanced (Bank #2)
P1387
Variable Cam Timing Solenoid #2 Circuit Malfunction
P1388
Variable Cam Timing Overretarded (Bank #2)
P1389
Glow Plug Circuit High Side Low Input
P1390
Octane Adjust Pin Out Of Self Test Range
P1391
Glow Plug Circuit Low Input (Bank #1)
P1392
Glow Plug Circuit High Input (Bank #1)
P1393
Glow Plug Circuit Low Input (Bank #2)
P1394
Glow Plug Circuit High Input (Bank #2)
P1395
Glow Plug Monitor Fault (Bank #1)
P1396
Glow Plug Monitor Fault (Bank #2)
P1397
System Voltage Out Of Self Test Range
P1398
VVT Solenoid B Circuit High Input
P1399
Glow Plug Circuit High Side, High Input
P1400
DPFE Circuit Low Input
P1401
DPFE Circuit High Input
P1402
EGR Metering Orifice Restricted
P1403
DPFE Sensor Hoses Reversed
P1404
IAT - B Circuit Malfunction/ Exhaust Gas Recirculation Closed Position Performance
P1405
DPFE Sensor Upstream Hose Off Or Plugged
P1406
Exhaust Gas Recirculation (EGR) Position Sensor Performance
P1407
EGR No Flow Detected
P1408
EGR Flow Out Of Self Test Range
P1409
EVR Control Circuit Malfunction
P1411
SAI System Incorrect Downstream Flow Detected
P1413
SAI System Monitor Circuit Low Input
P1414
SAI System Monitor Circuit High Input
P1415
Air Pump Circuit Malfunction/ (AIR) System Bank 1
P1416
Port Air Circuit Malfunction/ (AIR) System Bank 2
P1417
Port Air Relief Circuit Malfunction
P1418
Split Air #1 Circuit Malfunction
P1419
Split Air #2 Circuit Malfunction
P1420
Catalyst Temperature Sensor Failure
P1421
Catalyst Damage
P1422
EGI Temperature Sensor Failure
P1423
EGI Functionality Test Failed
P1424
EGI Glow Plug Primary Failure
P1425
EGI Glow Plug Secondary Failure
P1426
EGI Mini - MAF Failed Out Of Range
P1427
EGI Mini - MAF Failed Short Circuit
P1428
EGI Mini - MAF Failed Open Circuit
P1429
Electric Air Pump Primary Failure
P1430
Electric Air Pump Secondary Failure
P1433
A/C Refrigerant Temperature Circuit Low
P1434
A/C Refrigerant Temperature Circuit High
P1435
A/C Refrigerant Temperature Circuit Range/Performance
P1436
A/C Evaporator Air Temperature Circuit Low
P1437
A/C Evaporator Air Temperature Circuit High
P1438
A/C Evaporator Air Temperature Circuit Range/Performance
P1439
Floor Temperature Switch Circuit Malfunction
P1440
Purge Valve Stuck Open
P1441
Evaporative Emission (EVAP) System Flow During Non-Purge Chevrolet Only
P1441
Evaporative Emission (EVAP) System Flow During Non-Purge Oldsmobile Only
P1442
P1443
Evaporative Emission Control System Control Valve
P1444
P1445
P1446
Evaporative Vac Solenoid Circuit Malfunction
P1447
ELC System Closure Valve Flow Fault
P1448
ELC System 2 Fault
P1449
Evaporative Check Solenoid Circuit Malfunction
P1450
Unable To Bleed Up Fuel Tank Vacuum
P1451
Evap Emission Control Sys Vent Control Valve Circuit
P1452
Unable To Bleed - Up Vacuum in Tank
P1453
Fuel Tank Pressure Relief Valve Malfunction
P1454
Evaporative System Vacuum Test Malfunction
P1455
Evap Emission Control Sys Leak Detected (Gross Leak/No Flow)
P1456
Fuel Tank Temperature Sensor Circuit Malfunction
P1457
Unable To Pull Vacuum In Tank
P1460
Wide open throttle A/C cutoff relay circuit
P1461
A/C pressure sensor circuit voltage low
P1462
A/C pressure sensor circuit voltage high
P1463
A/C Pressure Sensor Insufficient Pressure Change
P1464
A/C Demand Out of Self Test Range
P1465
A/C Relay Circuit Malfunction
P1466
A/C Refrigerant Temperature Sensor/Circuit Malfunction
P1467
A/C Compressor Temperature Sensor Malfunction
P1468
SSPOD Open Circuit or Closed Circuit Fault
P1469
Low A/C Cycling Period
P1470
A/C Cycling Period Too Short
P1471
Electrodrive Fan 1 Operational Failure (Driver Side)
P1472
Electrodrive Fan 2 Operational Failure (Passenger Side)
P1473
Fan Secondary High With Fan(s) Off
P1474
Low Fan Control Primary Circuit Malfunction
P1475
Fan Relay (Low) Circuit Malfunction
P1476
Fan Relay (High) Circuit Malfunction
P1477
Additional Fan Relay Circuit Malfunction
P1478
Cooling Fan Driver Fault
P1479
High Fan Control Primary Circuit Malfunction
P1480
Fan Secondary Low with Low Fan On
P1481
Fan Secondary Low With High Fan On
P1482
SCP
P1483
Power To Fan Circuit Overcurrent
P1484
Open Power To Ground VCRM
P1485
EGRV Circuit Malfunction
P1486
EGRA Circuit Malfunction
P1487
EGRCHK Solenoid Circuit Malfunction
P1490
Secondary Air Relief Solenoid Circuit Malfunction
P1491
Secondary Switch Solenoid Circuit Malfunction
P1492
APLSOL Solenoid Circuit Malfunction
P1493
RCNT Solenoid Circuit Malfunction
P1494
SPCUT Solenoid Circuit Malfunction
P1495
TCSPL Solenoid Circuit Malfunction
P1500
P1501
Vehicle Speed Sensor Out Of Self Test Range
P1502
Vehicle Speed Sensor Intermittent Malfunction
P1503
Auxillary Speed Sensor Fault
P1504
Idle Air Control Circuit Malfunction
P1505
Idle Air Control System At Adaptive Clip
P1506
Idle Air Control Overspeed Error
P1507
Idle Air Control Underspeed Error
P1508
Idle Control System Circuit Open
P1509
Idle Control System Circuit Shorted
P1510
Idle Signal Circuit Malfunction
P1511
Idle Switch (Electric Control Throttle) Circuit Malfunction
P1512
Intake Manifold Runner Control (Bank 1) Stuck Closed
P1513
Intake Manifold Runner Control (Bank 2) Stuck Closed
P1514
High Load Neutral/Drive Fault
P1515
Electric Current Circuit Malfunction
P1516
IMRC Input Error (Bank 1)
P1517
IMRC Input Error (Bank 2)
P1518
Intake Manifold Runner Control (Stuck Open)
P1519
Intake Manifold Runner Control (Stuck Closed)
P1520
Intake Manifold Runner Control Circuit Malfunction
P1521
Variable Intake Solenoid #1 Circuit Malfunction
P1522
Variable Intake Solenoid #2 Circuit Malfunction
P1523
IVC Solenoid Circuit Malfunction
P1524
Variable Intake Solenoid System
P1525
Air Bypass Valve System
P1526
Air Bypass System
P1527
Accelerate Warmup Solenoid Circuit Malfunction
P1528
Subsidiary Throttle Valve Solenoid Circuit Malfunction
P1529
SCAIR Solenoid Circuit Malfunction
P1530
A/C Clutch Circuit Malfunction
P1531
Invalid Test - Accelerator Pedal Movement
P1532
IMCC Circuit Malfunction, Bank B
P1533
AAI Circuit Malfunction
P1534
Inertia Switch Activated
P1535
Blower Fan Speed Circuit Range/Performance
P1536
Parking Brake Switch Circuit Failure
P1537
Intake Manifold Runner Control (Bank 1) Stuck Open
P1538
Intake Manifold Runner Control (Bank 2) Stuck Open
P1539
Power To A/C Clutch Circuit Overcurrent
P1540
Air Bypass Valve Circuit Malfunction
P1549
P1550
PSPS Out Of Self Test Range
P1565
Speed Control Command Switch Out of Range High
P1566
Speed Control Command Switch Out of Range Low
P1567
Speed Control Output Circuit Continuity
P1568
Speed Control Unable to Hold Speed
P1571
Brake Switch Malfunction
P1572
Brake Pedal Switch Circuit Malfunction
P1573
Throttle Position Not Available
P1574
Throttle Position Sensor Disagreement btwn Sensors
P1575
Pedal Position Out of Self Test Range
P1576
Pedal Position Not Available
P1577
Pedal Position Sensor Disagreement btwn Sensors
P1578
ETC Power Less Than Demand
P1579
ETC In Power Limiting Mode
P1580
Electronic Throttle Monitor PCM Override
P1581
Electronic Throttle Monitor Malfunction
P1582
Electronic Throttle Monitor Data Available
P1583
Electronic Throttle Monitor Cruise Disable
P1584
TCU Detected IPE Circuit Malfunction
P1585
Throttle Control Unit Malfunction
P1586
Throttle Control Unit Throttle Position Malfunction
P1587
Throttle Control Unit Modulated Command Malfunction
P1588
Throttle Control Unit Detected Loss of Return Spring
P1589
TCU Unable To Control Desired Throttle Angle
P1600
Loss of KAM Power; Open Circuit
P1601
ECM/TCM Serial Communication Error
P1602
Immobilizer/ECM Communication Error
P1603
EEPROM Malfunction
P1604
Code Word Unregestered
P1605
Keep Alive Memory Test Failure
P1606
ECM Control Relay O/P Circuit Malfunction
P1607
MIL O/P Circuit Malfunction
P1608
Internal ECM Malfunction
P1609
Diagnostic Lamp Driver Fault
P1610
SBDS Interactive Codes
P1611
P1612
P1613
P1614
P1615
P1616
P1617
P1618
P1619
P1620
P1621
Control Module Long Term Memory Performance/ Immobilizer Code Words Do Not Match
P1622
Immobilizer ID Does Not Match
P1623
Immobilizer Code Word/ID Number Write Failure
P1624
Anti Theft System
P1625
B+ Supply To VCRM Fan Circuit Malfunction
P1626
Theft Deterrent Fuel Enable Signal Not Received/ B+ Supply To VCRM A/C Circuit Malfunction
P1627
Module Supply Voltage Out Of Range
P1628
Module Ignition Supply Input Malfunction
P1629
Internal Voltage Regulator Malfunction
P1630
Internal Vref Malfunction
P1631
Theft Deterrent Start Enable Signal Not Correct/ Main Relay Malfunction (Power Hold)
P1632
Smart Alternator Faults Sensor/Circuit Malfunction
P1633
KAM Voltage Too Low
P1634
Data Output Link Circuit Failure
P1635
Tire / Axle Ratio Out of Acceptable Range
P1636
Inductive Signature Chip Communication Error
P1637
Can Link ECM/ABSCM Circuit / Network Malfunction
P1638
Can Link ECM/INSTM Circuit / Network Malfunction
P1639
Vehicle ID Block Corrupted or Not Programmed
P1640
Powertrain DTCs Available in Another Module
P1641
Fuel Pump Primary Circuit Failure
P1642
Fuel Pump Monitor Circuit High Input
P1643
Fuel Pump Monitor Circuit Low Input
P1644
Fuel Pump Speed Control Circuit Malfunction
P1645
Fuel Pump Resistor Switch Circuit Malfunction
P1650
PSP Switch Out of Self Test Range
P1651
PSP Switch Input Malfunction
P1652
IAC Monitor Disabled by PSP Switch Failed On
P1653
Power Steering Output Circuit Malfunction
P1654
Recirculation Override Circuit Malfunction
P1655
Starter Disable Circuit Malfunction
P1660
Output Circuit Check Signal High
P1661
Output Circuit Check Signal Low
P1662
IDM_EN Circuit Failure
P1663
Fuel Demand Command Signal Circuit Malfunction
P1667
CI Circuit Malfunction
P1668
PCM - IDM Communications Error
P1670
Electronic Feedback Signal Not Detected
P1680
Metering Oil Pump Malfunction
P1681
P1682
P1683
Metering Oil Pump Temperature Sensor Circuit Malfunction
P1684
Metering Oil Pump Position Sensor Circuit Malfunction
P1685
Metering Oil Pump Stepping Motor Circuit Malfunction
P1686
P1687
P1688
P1689
Oil Pressure Control Solenoid Circuit Malfunction
P1690
Wastegate Solenoid Circuit Malfunction
P1691
Turbo Pressure Control Solenoid Circuit Malfunction
P1692
Turbo Control Solenoid Circuit Malfunction
P1693
Turbo Charge Control Circuit Malfunction
P1694
Turbo Charge Relief Circuit Malfunction
P1700
Transmission Indeterminate Failure (Failed to Neutral)
P1701
Reverse Engagement Error
P1702
TRS Circuit Intermittent Malfunction
P1703
Brake Switch Out Of Self Test Range
P1704
Digital TRS Failed to Transition States in KOEO / KOER
P1705
Not in P or N During KOEO / KOER
P1706
High Vehicle Speed Observed in Park
P1707
Transfer Case Neutral Indicator Hard Fault Present
P1708
Clutch Switch Circuit Malfunction
P1709
PNP Switch Out Of Self Test Range
P1711
TFT Sensor Out Of Self Test Range
P1712
Trans Torque Reduction Request Signal Malfunction
P1713
TFT Sensor In Range Failure Low Value
P1714
SSA Inductive Signature Malfunction
P1715
SSB Inductive Signature Malfunction
P1716
SSC Inductive Signature Malfunction
P1717
SSD Inductive Signature Malfunction
P1718
TFT Sensor In Range Failure High
P1720
Vehicle Speed (Meter) Circuit Malfunction
P1721
Gear 1 Incorrect Ratio
P1722
Gear 2 Incorrect Ratio
P1723
Gear 3 incorrect Ratio
P1724
Gear 4 Incorrect Ratio
P1725
Insufficient Engine Speed Increase During Self Test
P1726
Insufficient Engine Speed Decrease During Self Test
P1727
Coast Clutch Solenoid Inductive Signature Malfunction
P1728
Transmission Slip Error
P1729
4x4 Low Switch Error
P1730
Gear Control Malfunction 2,3,5
P1731
P1732
P1733
P1734
P1735
First Gear Switch Circuit Malfunction
P1736
Second Gear Switch Circuit Malfunction
P1737
Lockup Solenoid System
P1738
Shift Time Error
P1739
Slip Solenoid System
P1740
Torque Converter Clutch Inductive Signature Malfunction
P1741
Torque Converter Clutch Control Error
P1742
Torque Converter Clutch Solenoid Failed On
P1743
Torque Converter Clutch Solenoid Failied On
P1744
Torque Converter Clutch System Performance
P1745
Line Pressure Solenoid System
P1746
Pressure Control Solenoid "A" Open Circuit
P1747
Pressure Control Solenoid "A" Short Circuit
P1748
EPC Malfunction
P1749
Pressure Control Solenoid Failed Low
P1751
P1754
Coast Clutch Solenoid Circuit Malfunction
P1755
Intermediate Speed Sensor (ISS) Malfunction
P1756
P1760
P1761
P1762
Overdrive Band Failed Off
P1765
Timing Solenoid Circuit Malfunction
P1767
Torque Converter Clutch Circuit Malfunction
P1768
Performance / Normal / Winter Mode Input Malfunction
P1769
AG4 Transmission Torque Modulation Fault
P1770
P1775
Transmission System MIL Fault
P1776
Ignition Retard Request Duration Fault
P1777
Ignition Retard Request Circuit Fault
P1778
Transmission Reverse I/P Circuit Malfunction
P1779
TCIL Circuit Malfunction
P1780
Trans Control Switch (O/D Cancel) Out of Self Test Range
P1781
4X4 Switch Out of Self Test Range
P1782
P/ES Circuit Out Of Self Test Range
P1783
Transmission Overtemperature Condition
P1784
Transmission Mechanical Failure - First And Reverse
P1785
Transmission Mechanical Failure - First And Second
P1786
3-2 Downshift Error
P1787
2-1 Downshift Error
P1788
Pressure Control Solenoid "B" Open Circuit
P1789
Pressure Control Solenoid "B" Short Circuit
P1790
TP (Mechanical) Circuit Malfunction
P1791
TP (Electric) Circuit Malfunction
P1792
Barometer Pressure Circuit Malfunction
P1793
Intake Air Volume Circuit Malfunction
P1794
Battery Voltage Circuit Malfunction
P1795
Idle Switch Circuit Malfunction
P1796
Kick Down Switch Circuit Malfunction
P1797
Neutral Switch Circuit Malfunction
P1798
P1799
Hold Switch Circuit Malfunction
P1800
Transmission Clutch Interlock Safety Switch Circuit Failure
P1801
Transmission Clutch Interlock Safety Switch Open Circuit
P1802
Transmission Clutch Interlock Safety Switch Short Circuit To Battery
P1803
Transmission Clutch Interlock Safety Switch Short Circuit To Ground
P1804
Transmission 4-Wheel Drive High Indicator Circuit Failure
P1805
Transmission 4-Wheel Drive High Indicator Open Circuit
P1806
Transmission 4-Wheel Drive High Indicator Short Circuit To Battery
P1807
Transmission 4-Wheel Drive High Indicator Short Circuit To Ground
P1808
Transmission 4-Wheel Drive Low Indicator Circuit Failure
P1809
Transmission 4-Wheel Drive Low Indicator Open Circuit
P1810
TFP Valve Position Switch Circuit/ Transmission 4-Wheel Drive Low Indicator Short Circuit To Battery
P1811
Transmission 4-Wheel Drive Low Indicator Short Circuit To Ground
P1812
Transmission 4-Wheel Drive Mode Select Circuit Failure
P1813
Transmission 4-Wheel Drive Mode Select Open Circuit
P1814
Transmission 4-Wheel Drive Mode Select Short Circuit To Battery
P1815
Transmission 4-Wheel Drive Mode Select Short Circuit To Ground
P1816
Transmission Neutral Safety Switch Circuit Failure
P1817
Transmission Neutral Safety Switch Open Circuit
P1818
Transmission Neutral Safety Switch Short Circuit To Battery
P1819
Transmission Neutral Safety Switch Short Circuit To Ground
P1820
Transmission Transfer Case Clockwise Shift Relay Coil Circuit Failure
P1821
Transmission Transfer Case Clockwise Shift Relay Coil Open Circuit
P1822
Transmission Transfer Case Clockwise Shift Relay Coil Short Circuit To Battery
P1823
Transmission Transfer Case Clockwise Shift Relay Coil Short Circuit To Ground
P1824
Transmission 4-Wheel Drive Clutch Relay Circuit Failure
P1825
Transmission 4-Wheel Drive Clutch Relay Open Circuit
P1826
Transmission 4-Wheel Drive Low Clutch Relay Circuit To Battery
P1827
Transmission 4-Wheel Drive Low Clutch Relay Circuit To Ground
P1828
Transmission Transfer Case Counter Clockwise Shift Relay Coil Circuit Failure
P1829
Transmission Transfer Case Counter Clockwise Shift Relay Coil Open Circuit
P1830
Transmission Transfer Case Counter Clockwise Shift Relay Coil Short Circuit To Battery
P1831
Transmission Transfer Case Counter Clockwise Shift Relay Coil Short Circuit To Ground
P1832
Transmission Transfer Case Differential Lock-Up Solenoid Circuit Failure
P1833
Transmission Transfer Case Differential Lock-Up Solenoid Open Circuit
P1834
Transmission Transfer Case Differential Lock-Up Solenoid Short Circuit To Battery
P1835
Transmission Transfer Case Differential Lock-Up Solenoid Short Circuit To Ground
P1836
Transmission Transfer Case Front Shaft Speed Sensor Circuit Failure
P1837
Transmission Transfer Case Rear Shaft Speed Sensor Circuit Failure
P1838
Transmission Transfer Case Shift Motor Circuit Failure
P1839
Transmission Transfer Case Shift Motor Open Circuit
P1840
Transmission Transfer Case Shift Motor Short Circuit To Battery
P1841
Transmission Transfer Case Shift Motor Short Circuit To Ground
P1842
Transmission Transfer Case Differential Lock-Up Feedback Switch Circuit Failure
P1843
Transmission Transfer Case Differential Lock-Up Feedback Switch Open Circuit
P1844
Transmission Transfer Case Differential Lock-Up Feedback Switch Short Circuit To Battery
P1845
Transmission Transfer Case Differential Lock-Up Feedback Switch Short Circuit To Ground
P1846
Transmission Transfer Case Contact Plate 'A' Circuit Failure
P1847
Transmission Transfer Case Contact Plate 'A' Open Circuit
P1848
Transmission Transfer Case Contact Plate 'A' Short Circuit To Battery
P1849
Transmission Transfer Case Contact Plate 'A' Short Circuit To Ground
P1850
Transmission Transfer Case Contact Plate 'B' Circuit Failure
P1851
Transmission Transfer Case Contact Plate 'B' Open Circuit
P1852
Transmission Transfer Case Contact Plate 'B' Short Circuit To Battery
P1853
Transmission Transfer Case Contact Plate 'B' Short Circuit To Ground
P1854
Transmission Transfer Case Contact Plate 'C' Circuit Failure
P1855
Transmission Transfer Case Contact Plate 'C' Open Circuit
P1856
Transmission Transfer Case Contact Plate 'C' Short Circuit To Battery
P1857
Transmission Transfer Case Contact Plate 'C' Short Circuit To Ground
P1858
Transmission Transfer Case Contact Plate 'D' Circuit Failure
P1859
Transmission Transfer Case Contact Plate 'D' Open Circuit
P1860
TCC PWM Solenoid Circuit Electrical/ Transmission Transfer Case Contact Plate 'D' Short Circuit To Battery
P1861
Transmission Transfer Case Contact Plate 'D' Short Circuit To Ground
P1862
Transmission Transfer Case Contact Plate Power Circuit Failure
P1863
Transmission Transfer Case Contact Plate Power Open Circuit
P1864
Transmission Transfer Case Contact Plate Power Short To Battery
P1865
Transmission Transfer Case Contact Plate Power Short To Ground
P1866
Transmission Transfer Case System Concern - Servicing Required
P1867
Transmission Transfer Case Contact Plate General Circuit Failure
P1868
Transmission Automatic 4-Wheel Drive Indicator (Lamp) Circuit Failure
P1869
Transmission Automatic 4-Wheel Drive Indicator (Lamp) Circuit Short To Battery
P1870
Transmission Component Slipping/ Transmission Mechanical Transfer Case 4x4 Switch Circuit Failure
P1871
Transmission Mechanical Transfer Case 4x4 Switch Circuit Short To Battery
P1872
Transmission Mechanical 4-Wheel Drive Axle Lock Lamp Circuit Failure
P1873
Transmission Mechanical 4-Wheel Drive Axle Lock Lamp Circuit Short To Battery
P1874
Transmission Automatic Hall Effect Sensor Power Circuit Failure
P1875
Transmission Automatic Hall Effect Sensor Power Circuit Short To Battery / 4WD Low Switch Circuit Electrical
P1876
Transmission Transfer Case 2-Wheel Drive Solenoid Circuit Failure
P1877
Transmission Transfer Case 2-Wheel Drive Solenoid Circuit Short To Battery
P1878
Transmission Transfer Case Disengaged Solenoid Circuit Failure
P1879
Transmission Transfer Case Disengaged Solenoid Open Circuit
P1880
Transmission Transfer Case Disengaged Solenoid Short to Battery
P1881
Engine Coolant Level Switch Circuit Failure, GEM
P1882
Engine Coolant Level Switch Circuit Short to Ground
P1883
P1884
Engine Coolant Level Lamp Circuit Short to Ground
P1885
Transmission Transfer Case Disengaged Solenoid Short to Ground
P1886
4X4 Initialization Failure
P1890
Transmission 4WD Mode Select Return Input Circuit Failure
P1891
Transmission Transfer Case Contact Plate Ground Return Open Circuit
P1900
OSS Circuit Intermittent Malfunction
P1901
TSS Circuit Intermittent Malfunction
P1902
Pressure Control Solenoid "B" Intermittent Short
P1903
Pressure Control Solenoid "C" Short Circuit
P1904
Pressure Control Solenoid "C" Open Circuit
P1905
Pressure Control Solenoid "C" Intermittent Short
P1906
Kickdown Pull Relay Open or Short Circuit to Ground
P1907
Kickdown Hold Relay Open or Short Circuit to Ground
P1908
Transmission Pressure Circuit Solenoid Open or Short to Ground
P1909
Trans Temp Sensor Circuit Open or Shorted to Pwr or Gnd
P1910
VFS A Pressure Output Failed Low
P1911
VFS B Pressure Output Failed Low
P1912
VFS C Pressure Output Failed Low
P1913
Pressure Switch A Circuit Malfunction
P1914
Manually Shifted Automatic (MSA) Sw Circuit Malf
P1915
Reverse Switch Circuit Malfunction
P1916
High Clutch Drum Speed Sensor Malfunction
P1917
High Clutch Drum Speed Sensor Intermittent
P1918
Transmission Range Display Circuit Malfunction
Re: Seznam chybovych kodu
Napsal: 19 lis 2009, 18:56
od mad mike
hezká práce :wink: , ale chtělo by to i přeložit
Napsal: 19 lis 2009, 22:11
od SHANE54
no to je haluz, ze kolko chyb moze byt na stile... ak chce niekto nieco prelozit, pomozem, ale nemozem prelozit vsetko...
Napsal: 09 lis 2010, 12:29
od janS
Co je to ta 0170? fuel trim... Hlavne ten bank1? vie niekto.
Napsal: 15 lis 2010, 13:43
od radek66
P0100
Hmotnosť alebo objem prietoku vzduchu obvod Závada
P0101
Hmotnosť alebo objem prietoku vzduchu okruhu Range / výkon Problem
P0102
Hmotnosť alebo objem prietoku vzduchu Nízky vstupný obvod
P0103
Hmotnosť alebo objem prietoku vzduchu obvode vysokú vstupnú
P0104
Hmotnosť alebo objem prietoku vzduchu obvod Prerušovaný
P0105
Absolútny tlak potrubie / barometrického tlaku obvod Závada
P0106
Absolútny tlak potrubie / barometrického tlaku okruhu Range / výkon Problem
P0107
Absolútny tlak potrubie / barometrického tlaku Nízky vstupný obvod
P0108
Absolútny tlak potrubie / barometrického tlaku obvod vysokú vstupnú
P0109
Absolútny tlak potrubie / barometrického tlaku obvod Prerušovaný
P0109
Teplota nasávaného vzduchu obvod Závada
P0110
IAT obvod Závada
P0111
Teplota nasávaného vzduchu okruhu Range / výkon Problem
P0112
Teplota nasávaného vzduchu Nízky vstupný obvod
P0113
Teplota nasávaného vzduchu obvode vysokú vstupnú
P0114
Teplota nasávaného vzduchu obvod Prerušovaný
P0115
Teplota chladiaceho média motora v obvode Závada
P0116
Teplota chladiaceho média motora v obvode Range / výkon Problem
P0117
Teplota chladiaceho média motora v obvode Nízky vstupný
P0118
Teplota chladiaceho média motora v obvode vysokou vstupnou
P0119
Teplota chladiaceho média motora v obvode Prerušovaný
P0120
Snímač polohy klapky / Switch obvod Závada
P0121
Snímač polohy klapky / Switch okruhu Range / výkon Problem
P0122
Snímač polohy klapky / Switch Nízky vstupný obvod
P0123
Snímač polohy klapky / Switch obvod vysokú vstupnú
P0124
Snímač polohy klapky / Switch obvod Prerušovaný
P0125
Nedostatočná teplota chladiacej kvapaliny pre uzavreté regulačné slučka paliva;
ECT Nadmerné Čas Uzavretá slučka riadenia paliva
P0126
Nedostatočná teplota chladiacej kvapaliny pre stabilnú prevádzku
P0128
Chladiacej kvapaliny Termostat Závada
P0130
O2 obvodu snímača závada (banka 1 Snímač 1)
P0131
O2 obvode snímača Low Voltage (banka 1 senzor 1)
P0132
O2 obvode snímača High Voltage (banka 1 Snímač 1)
P0133
O2 obvode snímača pomalá odozva (banka 1 senzor 1)
P0134
O2 senzora obvod č aktivita Našiel (banka 1 senzor 1)
P0135
O2 senzor obvod ohrievače závada (banka 1 Snímač 1)
P0136
O2 obvodu snímača závada (banka 1 Snímač 2)
P0137
O2 obvode snímača Low Voltage (banka 1 Snímač 2)
P0138
O2 obvode snímača High Voltage (banka 1 Snímač 2)
P0139
O2 obvode snímača pomalá odozva (banka 1 Snímač 2)
P0140
O2 senzora obvod č aktivita Našiel (banka 1 senzor 2)
P0141
O2 senzora obvod ohrievače závada (banka 1 senzor 2)
P0142
O2 obvodu snímača závada (banka 1 Snímač 3)
P0143
O2 obvode snímača Low Voltage (banka 1 Snímač 3)
P0144
O2 obvode snímača High Voltage (banka 1 Snímač 3)
P0145
O2 obvode snímača pomalá odozva (banka 1 Snímač 3)
P0146
O2 senzora obvod č aktivita Našiel (banka 1 snímač 3)
P0147
O2 senzora obvod ohrievače závada (banka 1 snímač 3)
P0150
O2 obvodu snímača závada (banka 2 snímače 1)
P0151
O2 obvode snímača Low Voltage (banka 2 snímače 1)
P0152
O2 senzor obvodu vysokého napätia (banka 2 snímače 1)
P0153
O2 obvode snímača pomalá odozva (banka 2 snímače 1)
P0154
O2 obvode snímača Žiadna aktivita Našiel (banka 2 snímače 1)
P0155
O2 senzor obvod ohrievače závada (banka 2 snímače 1)
P0156
O2 obvodu snímača závada (banka 2 snímače 2)
P0157
O2 obvode snímača Low Voltage (banka 2 čidlo 2)
P0158
O2 senzor obvodu vysokého napätia (banka 2 snímače 2)
P0159
O2 obvode snímača pomalá odozva (banka 2 snímače 2)
P0160
O2 senzora obvod č aktivita Našiel (banka 2 snímače 2)
P0161
O2 senzora obvod ohrievače závada (banka 2 snímače 2)
P0162
O2 obvodu snímača závada (banka 2 čidlo 3)
P0163
O2 obvode snímača Low Voltage (banka 2 snímače 3)
P0164
O2 obvode snímača High Voltage (banka 2 čidlo 3)
P0165
O2 obvode snímača pomalá odozva (banka 2 čidlo 3)
P0166
O2 obvode snímača Žiadna aktivita Našiel (banka 2 čidlo 3)
P0167
O2 senzor obvod ohrievače závada (banka 2 čidlo 3)
P0170
Palivá Trim Porucha (banka 1)
P0171
Palivá Trim Systém Lean (banka 1)
P0172
Palivá Trim príliš Rich (banka 1)
P0173
Palivá Trim Porucha (banka 2)
P0174
Palivá Trim príliš Lean (banka 2)
P0175
Palivá Trim príliš Rich (banka 2)
P0176
Zloženie paliva obvodu snímača Závada
P0177
Zloženie paliva obvodu snímača Range / výkon
P0178
Zloženie paliva obvode snímača Nízky vstupný
P0179
Zloženie paliva obvode snímača vysoké vstupné
P0180
Palivá snímača teploty okruhu Závada
P0181
Palivá snímača teploty okruhu Range / výkon
P0182
Palivá snímača teploty Nízky vstupný obvod
P0183
Palivá snímača teploty okruhu vysokú vstupnú
P0184
Palivá snímača teploty okruhu Prerušovaný
P0185
Snímače teploty paliva B obvod Závada
P0186
Snímače teploty paliva B obvod Range / výkon
P0187
Snímače teploty paliva B obvod Nízky vstupný
P0188
Snímače teploty paliva B obvod vysokú vstupnú
P0189
Snímače teploty paliva B obvod Prerušovaný
P0190
Palivá železničnej Tlakové obvodu snímača Závada
P0191
Palivá železničnej Tlakové obvodu snímača Range / výkon
P0192
Palivá železničnej Tlakové snímače Nízky vstupný obvod
P0193
Palivá železničnej Tlakové senzor Obvod vysokú vstupnú
P0194
Palivá železničnej Tlakové senzor Obvod Prerušovaný
P0195
Teplota oleja v motore Porucha snímača
P0196
Teplota oleja v motore čidla Dosah / výkon
P0197
Motorový olej snímača teploty Nízka
P0198
Teplota oleja v motore snímača vysokej
P0199
Motorový olej snímača teploty Prerušovaný
P0200
Injector obvod Závada
P0201
Vstrekovač obvode Závada - Valec 1
P0202
Vstrekovač obvode Závada - Valec 2
P0203
Vstrekovač obvode Závada - 3 valce
P0204
Vstrekovač obvode Závada - valec 4
P0205
Vstrekovač obvode Závada - valec 5
P0206
Vstrekovač obvodu Závada - valca 6
P0207
Vstrekovač obvode Závada - valec 7
P0208
Vstrekovač obvode Závada - valec 8
P0209
Vstrekovač obvode Závada - valec 9
P0210
Vstrekovač obvode Závada - valec 10
P0211
Vstrekovač obvode Závada - valec 11
P0212
Vstrekovač obvode Závada - valec 12
P0213
Studený štart Injector 1 Závada
P0214
Studený štart Injector 2 Závada
P0215
Motor Uzatváracie elektromagnetický Závada
P0216
Vstrekovacie časovanie ventilov obvod Závada
P0217
Motor prehriatiu Stav
P0218
Prenos cez teplotné pomery
P0219
Motor prekročenie rýchlosti Stav
P0220
Škrtiace / Petal snímač polohy / Switch B obvod Závada
P0221
Škrtiace / Petal snímač polohy / Switch B obvod Range / výkon Problem
P0222
Škrtiace / Petal snímač polohy / Switch B obvod Nízky vstupný
P0223
Škrtiace / Petal snímač polohy / Switch B obvod vysokú vstupnú
P0224
Škrtiace / Petal snímač polohy / Switch B obvod Prerušovaný
P0225
Škrtiace / Petal snímač polohy / Switch C obvod Závada
P0226
Škrtiace / Petal snímač polohy / Switch C okruhu Range / výkon Problem
P0227
Škrtiace / Petal snímač polohy / Switch C Nízky vstupný obvod
P0228
Škrtiace / Petal snímač polohy / Switch C obvodu vysokú vstupnú
P0229
Škrtiace / Petal snímač polohy / Switch C obvod Prerušovaný
P0230
Palivové čerpadlo primárneho okruhu Závada
P0231
Palivového čerpadla sekundárneho okruhu Nízka
P0232
Palivového čerpadla sekundárneho okruhu Vysoké
P0233
Palivového čerpadla sekundárneho okruhu Prerušovaný
P0234
Motor Overboost Stav
P0235
Turbodúchadla Boost senzora obvod Závada
P0236
Turbodúchadla Boost senzor Obvod Range / výkon
P0237
Turbodúchadla Boost Senzor A obvod Nízka
P0238
Turbodúchadla Boost senzor obvod Vysoké
P0239
Turbodúchadla Boost senzora B Závada
P0240
Turbodúchadla Boost senzora B obvod Range / výkon
P0241
Turbodúchadla Boost senzora B obvod Nízka
P0242
Turbodúchadla Boost senzor B obvod Vysoké
P0243
Turbodúchadla wastegate Solenoid Závada
P0244
Turbodúchadla wastegate Elektromagnetický Range / výkon
P0245
Turbodúchadla wastegate Solenoid Nízka
P0246
Turbodúchadla wastegate Solenoid vysokej
P0247
Turbodúchadla wastegate solenoidu B Závada
P0248
Turbodúchadla wastegate Elektromagnetický B Range / výkon
P0249
Turbodúchadla wastegate solenoidu B Nízka
P0250
Turbodúchadla wastegate solenoidu B Vysoké
P0251
Vstrekovacie čerpadlo dávkovanie paliva Control "A" Porucha (Cam / Rotor / Injector)
P0252
Vstrekovacie čerpadlo dávkovanie paliva Control "A" Rozsah / výkon (Cam / Rotor / Injector)
P0253
Vstrekovacie čerpadlo dávkovanie paliva Control "A" Low (Cam / Rotor / Injector)
P0254
Vstrekovacie čerpadlo dávkovanie paliva Control "A" High (Cam / Rotor / Injector)
P0255
Vstrekovacie čerpadlo dávkovanie paliva Control "A" prerušovaný (Cam / Rotor / Injector)
P0256
Vstrekovacie čerpadlo dávkovanie paliva Control "B" Porucha (Cam / Rotor / Injector)
P0257
Vstrekovacie čerpadlo dávkovanie paliva Control "B" Rozsah / výkon (Cam / Rotor / Injector)
P0258
Vstrekovacie čerpadlo dávkovanie paliva Control "B" Low (Cam / Rotor / Injector)
P0259
Vstrekovacie čerpadlo dávkovanie paliva Control "B" High (Cam / Rotor / Injector)
P0260
Vstrekovacie čerpadlo dávkovanie paliva Control "B" prerušovaný (Cam / Rotor / Injector)
P0261
Valec 1 Injector obvod Nízka
P0262
Valec 1 Injector obvod Vysoké
P0263
Valec 1 príspevok / Balance porucha
P0264
Valec 2 Injector obvod Nízka
P0265
Valec 2 Injector obvod Vysoké
P0266
Valec 2 Príspevok / Balance porucha
P0267
Valec 3 Injector okruh Nízka
P0268
Valec 3 Injector okruh Vysoké
P0269
Valec 3 Príspevok / Balance porucha
P0270
Valec 4 Injector obvod Nízka
P0271
Valec 4 Injector obvod Vysoké
P0272
Valec 4 Príspevok / Balance porucha
P0273
Valec 5 Injector obvod Nízka
P0274
Valec 5 Injector obvod Vysoké
P0275
Valec 5 Príspevok / Balance porucha
P0276
Valec 6 Injector obvod Nízka
P0277
Valec 6 Injector obvod Vysoké
P0278
Valec 6 Prínos / Balance porucha
P0279
Valec 7 Injector obvod Nízka
P0280
Valec 7 Injector obvod Vysoké
P0281
Valec 7 Príspevok / Balance porucha
P0282
Valec 8 Injector obvod Nízka
P0283
Valec 8 Injector obvod Vysoké
P0284
Valec 8 Príspevok / Balance porucha
P0285
Valec 9 Injector obvod Nízka
P0286
Valec 9 Injector obvod Vysoké
P0287
Valec 9 Príspevok / Balance porucha
P0288
Valec 10 Injector obvod Nízka
P0289
Valec 10 Injector obvod Vysoké
P0290
Valec 10 Príspevok / Balance porucha
P0291
Valec 11 Injector obvod Nízka
P0292
Valec 11 Injector obvod Vysoké
P0293
Valec 11 Príspevok / Balance porucha
P0294
Valec 12 Injector obvod Nízka
P0295
Valec 12 Injector obvod Vysoké
P0296
Valec 12 Príspevok / Range porucha
P0300
Náhodné prehrávanie / Viac vojne zlyhať zistený
P0301
Valec 1 zlyhať zistený
P0302
Valec 2 zlyhať zistený
P0303
Valec 3 zlyhať zistený
P0304
Valec 4 zlyhať zistený
P0305
Valec 5 zlyhať zistený
P0306
Valec 6 zlyhať zistený
P0307
Valec 7 zlyhať zistený
P0308
Valec 8 zlyhať zistený
P0309
Valec 9 zlyhať zistený
P0310
Valec 10 zlyhať zistený
P0311
Valec 11 zlyhať zistený
P0312
Valec 12 zlyhať zistený
P0320
Zapaľovanie / Distribútor Otáčky motora Vstupný obvod Závada
P0321
Zapaľovanie / Distribútor Otáčky motora vstupný obvod Rozsah / výkon
P0322
Zapaľovanie / Distribútor Otáčky motora Vstupný obvod č signál
P0323
Zapaľovanie / Distribútor Otáčky motora Vstupný obvod Prerušovaný
P0325
Knock čidlo 1 okruh závada (banka 1, alebo s jedným snímačom)
P0326
Knock senzor 1 okruh Range / výkon (banka 1, alebo s jedným snímačom)
P0327
Knock čidlo 1 okruh nízke vstupné náklady (banka 1, alebo s jedným snímačom)
P0328
Knock čidlo 1 okruh vysokej vstup (banka 1, alebo s jedným snímačom)
P0329
Knock čidlo 1 okruh Prerušovaný (banka 1, alebo s jedným snímačom)
P0330
Knock snímač 2 Obvodný závada (banka 2)
P0331
Knock senzor 2 Obvodný Range / výkon (banka 2)
P0332
Knock senzor 2 Obvodný nízke vstupné náklady (banka 2)
P0333
Knock senzor 2 Obvodný vysokej vstup (banka 2)
P0334
Knock snímač 2 Obvodný prerušovaný (banka 2)
P0335
Snímače polohy kľukového hriadeľa obvod Závada
P0336
Snímače polohy kľukového hriadeľa okruhu Range / výkon
P0337
Snímače polohy kľukového hriadeľa Nízky vstupný obvod
P0338
Snímače polohy kľukového hriadeľa obvode vysokú vstupnú
P0339
Snímače polohy kľukového hriadeľa obvod Prerušovaný
P0340
Snímače polohy vačkové hriadele obvod Závada
P0341
Vačkové hriadele snímača polohy okruhu Range / výkon
P0342
Snímače polohy vačkové hriadele Nízky vstupný obvod
P0343
Snímače polohy vačkové hriadele obvode vysokú vstupnú
P0344
Snímače polohy vačkové hriadele obvod Prerušovaný
P0350
Zapaľovacia cievka primárny / sekundárny okruh Závada
P0351
P0352
Zapaľovacie cievky B primárny / sekundárny okruh Závada
P0353
Zapaľovacie cievky C primárny / sekundárny okruh Závada
P0354
Zapaľovacie cievky D primárny / sekundárny okruh Závada
P0355
Zapaľovacia cievka E primárny / sekundárny okruh Závada
P0356
Zapaľovacia cievka F primárny / sekundárny okruh Závada
P0357
Zapaľovacia cievka G primárny / sekundárny okruh Závada
P0358
Zapaľovacia cievka H primárny / sekundárny okruh Závada
P0359
Zapaľovacie cievky I primárny / sekundárny okruh Závada
P0360
Zapaľovacia cievka J primárny / sekundárny okruh Závada
P0361
Zapaľovacie cievky K primárnej / sekundárny okruh Závada
P0362
Zapaľovacia cievka L primárny / sekundárny okruh Závada
P0370
Referencie načasovanie signálu s vysokým rozlíšením Závada
P0371
Referencie načasovanie signálu s vysokým rozlíšením príliš veľa impulzov
P0372
Referencie načasovanie signálu s vysokým rozlíšením príliš málo impulzov
P0373
Referencie načasovanie signálu s vysokým rozlíšením Prerušovaný / Nepravidelné pulzy
P0374
Referencie načasovanie signálu s vysokým rozlíšením č Strukoviny
P0375
Referencie načasovanie signálu s vysokým rozlíšením B Závada
P0376
Referencie načasovanie signálu s vysokým rozlíšením B príliš veľa impulzov
P0377
Referencie načasovanie signálu s vysokým rozlíšením B príliš málo impulzov
P0378
Referencie načasovanie signálu s vysokým rozlíšením B Prerušovaný / Nepravidelné pulzy
P0379
Referencie načasovanie signálu s vysokým rozlíšením B č Strukoviny
P0380
Žiara Plug / obvod ohrievače "A" Závada
P0381
Žiara Plug / ohrievač Indikátor obvod Závada
P0382
Recirkulácia výfukových plynov prietoku Závada
P0385
Kľukový hriadeľ snímača polohy B obvod Závada
P0386
Kľukový hriadeľ snímača polohy B obvod Range / výkon
P0387
Kľukový hriadeľ snímača polohy B obvod Nízky vstupný
P0388
Kľukový hriadeľ snímača polohy B obvod vysokú vstupnú
P0389
Kľukový hriadeľ snímača polohy B obvod Prerušovaný
P0400
P0401
Recirkulácia výfukových plynov prietoku Nedostatok zistený
P0402
Recirkulácia výfukových plynov prietoku Nadmerné zistený
P0403
Recirkulácia výfukových plynov obvod Závada
P0404
Recirkulácia výfukových plynov okruhu Range / výkon
P0405
Recirkulácia výfukových plynov senzor obvod Nízka
P0406
Recirkulácia výfukových plynov senzor obvod Vysoké
P0407
Recirkulácia výfukových plynov senzor B obvod Nízka
P0408
Recirkulácia výfukových plynov senzor B obvod Vysoké
P0410
Sekundárneho vzduchu poruchu systému
P0411
Sekundárneho vzduchu, systém Nesprávne prietoku zistený
P0412
Sekundárneho vzduchu, systém spínania ventilu obvode Závada
P0413
Sekundárneho vzduchu, systém spínania ventilu obvode Open
P0414
Sekundárneho vzduchu, systém spínania ventilu obvode skratovaný
P0415
Sekundárneho vzduchu, systém spínania ventilu B obvod Závada
P0416
Sekundárneho vzduchu, systém spínania ventilu B obvod Open
P0417
Sekundárneho vzduchu, systém spínania ventilu B obvod skratovaný
P0418
Sekundárneho vzduchu, systém Relay "A" obvod Závada
P0419
Sekundárneho vzduchu, systém Relay "B" obvod Závada
P0420
Catalyst účinnosť systému pod prahom (banka 1)
P0421
Warm Up Catalyst Účinnosť pod prahom (banka 1)
P0422
Hlavné Catalyst Účinnosť pod prahom (banka 1)
P0423
Vyhrievané Catalyst Účinnosť pod prahom (banka 1)
P0424
Vyhrievané Catalyst teploty pod prah (banka 1)
P0426
Catalyst teplotného senzora / výkon (banka 1)
P0427
Catalyst snímač teploty nízke vstupné náklady (banka 1)
P0428
Catalyst teplotné čidlo vysokej vstup (banka 1)
P0430
Catalyst účinnosť systému pod prahom (banka 2)
P0431
Warm Up Catalyst Účinnosť pod prahom (banka 2)
P0432
Hlavné Catalyst Účinnosť pod prahom (banka 2)
P0433
Vyhrievané Catalyst Účinnosť pod prahom (banka 2)
P0434
Vyhrievané Catalyst teploty pod prah (banka 2)
P0436
Catalyst teplotného senzora / výkon (banka 2)
P0437
Catalyst snímač teploty nízke vstupné náklady (banka 2)
P0438
Catalyst teplotné čidlo vysokej vstup (banka 2)
P0440
Obmedzenie emisií z odparovania poruchu systému
P0441
Reguláciu emisií výparu Nesprávne Purge prietoku
P0442
Reguláciu emisií z odparovania únik zistený (malý otvor)
P0443
Reguláciu emisií výparu očistenie ventil obvod Závada
P0444
Reguláciu emisií výparu očistenie ventil obvod Open
P0445
Reguláciu emisií výparu očistenie ventil obvod skratovaný
P0446
Reguláciu emisií výparu Vent riadiacich obvodov Závada
P0447
Reguláciu emisií výparu Vent riadiacich obvodov Open
P0448
Reguláciu emisií výparu Vent konania Skrátená obvod
P0449
Reguláciu emisií z odparovania odvzdušňovací ventil / elektromagnetický obvod Závada
P0450
Reguláciu emisií výparu Porucha snímača tlaku
P0451
Reguláciu emisií výparu tlaku Sensor Range / výkon
P0452
Reguláciu emisií výparu Tlakové senzor Nízky vstupný
P0453
Reguláciu emisií výparu Tlakové senzor vysokou vstupnou
P0454
Reguláciu emisií výparu Tlakové senzor Prerušovaný
P0455
Reguláciu emisií z odparovania únik zistený (brutto únik)
P0460
Snímač hladiny paliva obvod Závada
P0461
Snímač hladiny paliva okruhu Range / výkon
P0462
Snímač hladiny paliva Nízky vstupný obvod
P0463
Snímač hladiny paliva obvode vysokú vstupnú
P0464
Snímač hladiny paliva obvod Prerušovaný
P0465
Vyčistiť Plynový senzor Obvod Závada
P0466
Vyčistiť prietoku obvodu snímača Range / výkon
P0467
Vyčistiť prietoku senzora Nízky vstupný obvod
P0468
Vyčistiť prietoku obvode snímača vysoké vstupné
P0469
Vyčistiť Plynový senzor Obvod Prerušovaný
P0470
Tlak výfukového Porucha čidla
P0471
Tlak výfukového Sensor Range / výkon
P0472
Tlak výfukového plynu snímača Nízka
P0473
Tlak výfukového plynu snímača Vysoká
P0474
Tlak výfukového senzor Prerušovaný
P0475
Tlak výfukového regulačný ventil Závada
P0476
Výfukového tlaku ventil Rozsah / výkon
P0477
Tlak výfukového regulačný ventil nízkeho
P0478
Tlak výfukového regulačný ventil vysokej
P0479
Tlak výfukového regulačný ventil Prerušovaný
P0480
Chladiaci ventilátor 1 Ovládací obvod Závada
P0481
Chladiaci ventilátor 2 Ovládací obvod Závada
P0482
Chladiaci ventilátor 3 Kontrolné obvod Závada
P0483
Skontrolujte, či chladiaci ventilátor racionalita Závada
P0484
Chladiaci ventilátor okruh cez prúd
P0485
Chladiaci ventilátor napájanie / zem obvod Závada
P0500
Rýchlosť vozidla Porucha čidla
P0501
Rýchlosti vozidla Sensor Range / výkon
P0502
Snímač rýchlosti vozidla Nízky vstupný
P0503
Snímač rýchlosti vozidla Prerušovaný / Nepravidelné / Vysoká
P0505
Nečinnosti Control System Závada
P0506
Nečinnosti systému riadenia otáčok nižšie ako očakávané
P0507
Nečinnosti systému riadenia otáčok vyššie ako očakávané
P0510
Uzavretej polohy klapky Switch Závada
P0520
Motor tlaku oleja / Switch obvod Závada
P0521
Motor tlaku oleja / Switch okruhu Range / výkon
P0522
Motor tlaku oleja / Switch obvod nízkeho napätia
P0523
Motor tlaku oleja / Switch obvodu vysokého napätia
P0530
A / C Chladivo Tlakové čidlo obvode Závada
P0531
A / C Chladivo obvode snímače tlaku Rozsah / výkon
P0532
A / C Chladivo Tlakové čidlo obvode Nízky vstupný
P0533
A / C Chladivo Tlakové čidlo obvode vysokú vstupnú
P0534
Klimatizácia chladiva Strata
P0550
Tlakový senzor servo obvod Závada
P0551
Posilňovač riadenia tlaku obvodu snímača Range / výkon
P0552
Posilňovač riadenia tlaku obvode snímača Nízky vstupný
P0553
Posilňovač riadenia tlaku obvode snímača vysoké vstupné
P0554
Tlakový senzor servo obvod Prerušovaný
P0560
Systém napätia Závada
P0561
Systém napätia Nestabilné
P0562
Systém nízkom napätí
P0562
A / C snímač tlaku nízkeho napätia (Chrysler)
P0563
Systém napätia Vysoká
P0565
Tempomat na signál Závada
P0566
Tempomat vypnutie signálu Závada
P0567
Tempomat Pokračovať signálu Závada
P0568
Cruise regulačné sada signálu Závada
P0569
Tempomat pobrežie signálu Závada
P0570
Tempomat Accel signálu Závada
P0571
Tempomat / brzdový spínač obvodu Závada
P0572
Tempomat / brzdový spínač obvodu Nízka
P0573
Tempomat / brzdový spínač obvodu vysokého
P0574
Tempomat Súvisiace Závada
P0575
P0576
P0576
P0578
P0579
P0580
P0600
Sériovú komunikačnú linku Závada
P0601
Modul pre riadenie Read Only Memory (ROM)
P0602
Modul pre riadenie Programovanie Chyba
P0603
Vnútorná kontrola Modul Keep Alive pamäte (KAM), Chyba
P0604
Vnútorná kontrola modul Random Access Memory (RAM) Chyba
P0605
Vnútorná kontrola Modul Read Only Memory (ROM) Chyba
P0606
PCM Procesor poruchy
P0608
Modul pre riadenie VSS výstup "A" Závada
P0609
Modul pre riadenie VSS výstup "B" Závada
P0620
Generátor riadiaceho obvodu Závada
P0621
Generátor Lampa "L" ovládacieho obvodu Závada
P0622
Generátor poľa "F" ovládacieho obvodu Závada
P0650
Poruchy kontrolka (MIL) Ovládací obvod Závada
P0654
Otáčky motora výstupný obvod Závada
P0655
Motor Hot Lampa riadenie výstupu obvodu Malfucntion
P0656
Hladiny paliva výstupný obvod Závada
P0700
Transmission Control poruchu systému
P0701
Transmission Control Systém Range / výkon
P0702
Transmission Control Systém elektrickej
P0703
Meniče krútiaceho momentu / brzdový spínač B obvod Závada
P0704
Spojka Switch Vstupné obvod Závada
P0705
Dosah prenosu obvodu snímača závadu (PRNDL vstup)
P0706
Dosah prenosu obvodu snímača Rozsah / výkon
P0707
Postúpenie rozsah senzora Nízky vstupný obvod
P0708
Postúpenie rozsah senzora vysokú vstupný obvod
P0709
Postúpenie rozsah snímača obvod Prerušovaný
P0710
Postúpenie tekutín snímača teploty okruhu Závada
P0711
Postúpenie tekutín snímača teploty okruhu Range / výkon
P0712
Postúpenie tekutín snímača teploty Nízky vstupný obvod
P0713
Postúpenie tekutín snímača teploty okruhu vysokú vstupnú
P0714
Postúpenie tekutín snímača teploty okruhu Prerušovaný
P0715
Vstup / snímač otáčok turbíny obvod Závada
P0716
Vstup / turbína Snímač rýchlosti obvodov Rozsah / výkon
P0717
Vstup / turbína Snímač rýchlosti obvod č signál
P0718
Vstup / snímač otáčok turbíny obvod Prerušovaný
P0719
Meniče krútiaceho momentu / brzdový spínač B obvod Nízka
P0720
Výstupný snímač rýchlosti obvode Závada
P0721
Výstup snímačov rýchlosti Range / výkon
P0722
Výstupný snímač rýchlosti No Signal
P0723
Výstupný snímač rýchlosti Prerušovaný
P0724
Meniče krútiaceho momentu / brzdový spínač B obvod Vysoké
P0725
Otáčky motora vstupný obvod Závada
P0726
Otáčky motora Vstupný obvod Rozsah / výkon
P0727
P0728
Otáčky motora Vstupné obvod Prerušovaný
P0730
Nesprávne prevodový pomer
P0731
Prevodový pomer 1 Nesprávne
P0732
Nesprávny pomer Gear 2
P0733
Rýchlosť 3 Nesprávny pomer
P0734
Prevodový pomer 4 Nesprávne
P0735
Prevodový pomer 5 Nesprávne
P0736
Reverzné nesprávny prevodový pomer
P0740
Meniča krútiaceho momentu spojky obvod Malfuction
P0741
Meniča krútiaceho momentu spojky obvodu výkonu alebo Stuck Vypnuté
P0742
Meniča krútiaceho momentu spojky obvod Stuck On
P0743
Meniča krútiaceho momentu spojky obvode Elektrické
P0744
Meniča krútiaceho momentu spojky obvod Prerušovaný
P0745
Ovládací tlak solenoidu Závada
P0746
Kontrola tlaku v solenoidu výkonu alebo Stuck Vypnuté
P0747
Ovládací tlak solenoidu Stuck On
P0748
Ovládací tlak solenoidu Elektrické
P0749
Ovládací tlak solenoidu Prerušovaný
P0750
Shift Solenoid Závada
P0751
Shift solenoid výkonu alebo Stuck vypnuté /
1-2 Shift Elektromagnetický ventil Výkon
P0752
Shift solenoid Stuck On
P0753
Shift Elektromagnetický Elektrické /
1-2 Shift Solenoid obvode Elektrické
P0754
Shift Solenoid Prerušovaný
P0755
Shift solenoidu B Závada
P0756
Shift solenoidu B výkon alebo Stuck vypnuté /
2-3 Shift Elektromagnetický ventil Výkon
P0757
Shift solenoidu B Stuck On
P0758
Shift Elektromagnetický B Elektrické / 2-3 Shift solenoid obvode Elektrické
P0759
Shift elektromagnetom b Prerušovaný
P0760
Shift Solenoid C Závada
P0761
Shift Solenoid C Výkon alebo Stuck Vypnuté
P0762
P0763
Shift Solenoid C Elektrické
P0764
Shift Solenoid C Prerušovaný
P0765
Shift Solenoid D Závada
P0766
Shift solenoid D výkonu alebo Stuck Vypnuté
P0767
Shift solenoid D Stuck On
P0768
Shift Solenoid D Elektrické
P0769
Shift Solenoid D Prerušovaný
P0770
Shift Solenoid E Závada
P0771
Shift solenoid E výkon alebo Stuck Vypnuté
P0772
Shift solenoid E Stuck On
P0773
Shift Solenoid E Elektrická
P0774
Shift Solenoid E Prerušovaný
P0775
Ovládací tlak solenoidu B Závada
P0776
Ovládací tlak solenoidu B výkon
P0777
Ovládací tlak solenoidu B Stuck On
P0778
Kontrola tlaku v solenoidu B Elektrické
P0779
Ovládací tlak solenoidu B Prerušovaný
P0780
Shift Závada
P0781
1-2 Shift Závada
P0782
2-3 Shift Závada
P0783
3-4 Shift Závada
P0784
4-5 Shift Závada
P0785
Shift / Časovanie Elektromagnetický Závada / 3-2 Shift solenoid obvode Elektrické
P0786
Shift / Časovanie Elektromagnetický Range / výkon
P0787
Shift / časovanie Solenoid Nízka
P0788
Shift / časovanie Solenoid Vysoké
P0789
Shift / časovanie Solenoid Prerušovaný
P0790
Normálny / Performance Switch obvod Závada
P0801
Reverzné Zakázať ovládací obvod Závada
P0803
1-4 upshift (Prejdi Shift) Elektromagnetické ovládací obvod Závada
P0804
1-4 upshift (Prejdi Shift) Lampa riadiacich obvodov Závada
P1100
MAF senzora Občasné / Kontrola všetkých OBDII systémov nie je kompletný
P1101
MAF senzora Out Of Self Test Range. /
KOER nemohol dokončiť KOER Aborted
P1102
MAF senzora v rozmedzí, ale nižšie ako očakávané
P1103
MAF senzora v rozmedzí, ale vyššie ako sa očakávalo
P1104
MAF Pozemná Závada
P1105
Duálne Alternátor Horné poruchy
P1106
Duálne Alternátor Dolné Porucha / potrubie absolútny tlak (MAP), senzor obvode Prerušovaný veľmi vysokého napätia
P1107
Duálne Alternátor Dolné okruh Závada / rozdeľovač absolútny tlak (MAP), senzor obvode Prerušovaný nízkeho napätia
P1108
Duálne Alternátor Batérie lampa obvod Závada
P1109
IAT - B senzor Prerušované
P1110
IAT senzor (D / C), Open / Krátke
P1111
Teplota nasávaného vzduchu (IAT) senzor obvode Prerušovaný veľmi vysokého napätia
P1112
Teplota nasávaného vzduchu (IAT) senzor obvode Prerušovaný nízkeho napätia
P1113
IAT senzor Otvoriť / Krátke
P1114
Teplota chladiacej kvapaliny motora (ECT) obvodu snímača Prerušovaný Low Voltage / IAT - B obvod Nízky vstupný
P1115
Teplota chladiacej kvapaliny motora (ECT), senzor obvode Prerušovaný Vysoké napätie / IAT - B obvod vysokú vstupnú
P1116
Chladiacej kvapaliny motora snímača mimo rozsah / ECT senzor mimo Self Test Range
P1117
Chladiacej kvapaliny motora snímača intermitentná / ECT senzora Prerušovaný
P1118
Absolútna teplota potrubia Nízky vstupný obvod
P1119
Absolútna teplota potrubie okruhu vysokú vstupnú
P1120
Snímač polohy škrtiacej klapky mimo rozsah
P1121
Polohy škrtiacej klapky (TP), Občasné senzor obvodu vysokého napätia
P1122
Polohy škrtiacej klapky (TP) obvodu snímača Prerušovaný nízkeho napätia
P1123
Snímač polohy klapky v dosahu, ale vyššie ako sa očakávalo
P1124
Snímač polohy klapky Out Of Self Test Range
P1125
Snímač polohy škrtiacej klapky prerušovaný
P1126
Polohy škrtiacej klapky (úzkom rozmedzí), senzor obvod Závada
P1127
Výfukové Nie Teplé, Následní O2 senzor
P1128
Upstream Vyhrievané O2 senzory vymenil
P1129
Následný Vyhrievané O2 senzory vymenil
P1130
Nedostatok HO2S Switch - Adaptívne paliva pri Limit
P1131
Nedostatok HO2S Switch - Sensor Označuje Lean
P1132
Nedostatok HO2S Switch - Sensor Označuje Rich
P1133
HO2S Nedostatočné Spínacie snímač 1
P1134
HO2S prechodnú dobu snímač pomeru 1
P1135
Snímač polohy pedála obvod Prerušovaný
P1136
Fan Control obvod Závada
P1137
P1138
Nedostatok HO2S12 Switch - Sensor Označuje Rich
P1139
Voda v okruhu indikátor paliva Závada
P1140
Stav vody v palive
P1141
Palivá indikátorom obvod Závada
P1142
Stav paliva obmedzenia
P1143
Air Assist regulačný ventil Rozsah / výkon
P1144
Air Assist regulačný ventil obvod Závada
P1150
Nedostatok HO2S21 Switch - Adaptívne paliva pri Limit
P1151
Nedostatok HO2S21 Switch - Sensor Označuje Lean
P1152
Nedostatok HO2S21 Switch - Sensor Označuje Rich
P1153
Banka 2 palivové regulácie posunuté Lean
P1154
Banka 2 palivové regulácie posunuté Rich
P1155
Alternatívne palivá Regulátor
P1156
Palivá Prepínač Závada
P1157
Nedostatok HO2S22 Switch - Sensor Označuje Lean
P1158
Nedostatok HO2S22 Switch - Sensor Označuje Rich
P1159
Palivá krokového motora Závada
P1167
Neplatný test, plyn nie depresívne
P1168
Palivá železničnej senzor In-Range nízku poruchovosť
P1169
Palivá železničnej senzor In-Range vysokej zlyhanie
P1170
ESO - vypnutým motorom Solenoid poruchy
P1171
Rotora poruchy senzora
P1172
Ovládanie rotora poruchy
P1173
Rotor Kalibrácia poruchy
P1174
Cam závada snímača
P1175
Cam kontrolu chýb
P1176
Cam Kalibrácia poruchy
P1177
Porucha synchronizácia
P1178
(Otvorené)
P1180
Dodávka paliva poruchu systému - Low
P1181
Dodávka paliva poruchu systému - Vysoká
P1182
Palivá vypnutie Solenoid Závada
P1183
Teplota oleja v motore obvod Závada
P1184
Teplota oleja v motore Out Of Self Test Range
P1185
FTS High - Palivová čerpadlá snímač teploty vysoké
P1186
FTS Low - palivového čerpadla snímač teploty Nízka
P1187
Variant výber
P1188
Kalibračná pamäť porúch
P1189
Rýchlosť čerpadlá signálu poruchy
P1190
Kalibračné rezistor Out Of Range
P1191
Key Line napätie
P1192
Vonkajšie napätie
P1193
EGR Drive Nadmernému
P1194
ECU A / D prevodník
P1195
SCP HBCC Nepodarilo sa inicializovať
P1196
Key Off Vysoké napätie
P1197
Key Off nízkom napätí
P1198
Čerpadlo ovládanie rotora Underfueling
P1199
Hladiny paliva Vstupné obvod Nízka
P1200
Injector ovládacieho obvodu
P1201
Obvod vstrekovače Open / Skrátená - Valec # 1
P1202
Obvod vstrekovače Open / Skrátená - valec # 2
P1203
Obvod vstrekovače Open / Skrátená - valce # 3
P1204
Obvod vstrekovače Open / Skrátená - valce # 4
P1205
Obvod vstrekovače Open / Skrátená - valce # 5
P1206
Obvod vstrekovače Open / Skrátená - valce # 6
P1209
Vstrekovač kontrolu tlaku porucha systému
P1210
Vstrekovač kontrolu tlaku nad očakávanú úroveň
P1211
Vstrekovač kontrolu tlaku senzor nad / pod Požadovaný
P1212
Vstrekovač kontrolu tlaku nebol zistený počas Crank
P1213
Štart Injector obvod Závada
P1214
Snímač polohy pedála B obvod Prerušovaný
P1215
Snímač polohy pedálu C Nízky vstupný obvod
P1216
Snímač polohy pedálu C obvodu vysokú vstupnú
P1217
Snímač polohy pedálu C obvodu Prerušovaný
P1218
CID Vysoká
P1219
CID Nízka
P1220
Séria ovládanie plynu poruchu systému
P1221
Systém riadenia trakcie Závada
P1222
Systém riadenia trakcie výstupný obvod Závada
P1223
Pedál Dopyt senzor B obvod vysokú vstupnú
P1224
Snímač polohy klapky B Out Of Self Test Range
P1225
Zdvihnite ihlu Porucha čidla
P1226
Ovládanie rukáve Porucha čidla
P1227
Wastegate Nepodarilo Uzavreté (Over tlaku)
P1228
Wastegate Nepodarilo Open (Under Pressure)
P1229
Intercooler čerpadlo ovládače poruchy
P1230
Palivové čerpadlo Low Speed Závada
P1231
Palivového čerpadla sekundárneho okruhu Low, High Speed
P1232
Palivové čerpadlo rýchlosť primárneho okruhu Závada
P1233
Palivové čerpadlo ovládače modul Off Line
P1234
P1235
Palivového čerpadla Ovládacie Out Of Range
P1236
P1237
Palivového čerpadla sekundárneho okruhu Závada
P1238
P1239
Rýchlosť palivového čerpadla pozitívny ohlas poruchy
P1240
Napájanie snímača Závada
P1241
Čidlo napájanie Nízky vstupný
P1242
Napájanie snímača vysoké vstupné
P1243
Druhý palivového čerpadla Chybný alebo zemný
P1244
Alternátor zaťaženie Vstupné Nepodarilo Vysoká
P1245
Alternátor zaťaženie Vstupné Nepodarilo Nízka
P1246
Alternátor zaťaženie Vstupné zlyhalo
P1247
Turbo Boost nízkotlakového
P1248
Turbo Boost tlaku nebol zistený
P1249
Wastegate regulačný ventil Výkon
P1250
ČĽR Solenoid obvod Závada
P1251
Zmes vzduchu solenoidu obvod Závada
P1252
Korelácia PDS1 pedál a vysoký LPDs
P1253
Pedál Korelácia PDS1 a LPDs Nízka
P1254
Korelácia PDS2 pedál a vysoký LPDs
P1255
Pedál Korelácia PDS2 a LPDs Nízka
P1256
Pedál Korelácia PDS1 a HPDS
P1257
Pedál Korelácia PDS2 a HPDS
P1258
Pedál Korelácia PDS1 a PDS2
P1259
Imobilizér s PCM signálu Chyba
P1260
Zistené ODCUDZENIU, vozidlá Immobilzed
P1261
Valec # 1 najdrahšie strana Krátke
P1262
Valec # 2 najdrahšie strana Krátke
P1263
Valec # 3 najdrahšie strana Krátke
P1264
Valec # 4 najdrahšie strana Krátke
P1265
Valec # 5 najdrahšie strana Krátke
P1266
Valec # 6 najdrahšie strana Krátke
P1267
Valec # 7 najdrahšie strana Krátke
P1268
Valec # 8 najdrahšie strana Krátke
P1269
Imobilizér kód nie je naprogramovaný
P1270
Otáčky motora alebo obmedzovač rýchlosti Dosiahnutý
P1271
Valec # 1 najdrahšie Side Open
P1272
Valec # 2 najdrahšie Side Open
P1273
Valec # 3 najdrahšie Side Open
P1274
Valec # 4 najdrahšie Side Open
P1275
Valec # 5 najdrahšie Side Open
P1276
Valec # 6 najdrahšie Side Open
P1277
Valec # 7 najdrahšie Side Open
P1278
Valec # 8 najdrahšie Side Open
P1280
Vstrekovacie kontrolu tlaku Out Of Range Nízka
P1281
Vstrekovacie kontrolu tlaku Out Of Range Vysoká
P1282
Nadmerné Vstrekovacie kontrolu tlaku
P1283
IPR obvod zlyhanie
P1284
Aborted KOER - ICP zlyhanie
P1285
Hlavy valcov nad teplota snímaná
P1286
Palivo impulzu v rozmedzí, ale nižšie ako očakávané
P1287
Palivo impulzu v rozmedzí, ale vyššie ako sa očakávalo
P1288
Hlavy valcov Temp Senzorové Out Of Self Test Range
P1289
Hlavy valcov Temp Senzorové vysokú vstupnú
P1290
Hlavy valcov Temp Senzorové Nízky vstupný
P1291
Vstrekovač vysoké napätie Krátke na zem alebo VBATT - Banka 1
P1292
Vstrekovač vysoké napätie Krátke na zem alebo VBATT - banky 2
P1293
Vstrekovač vysoké napätie Open - Banka 1
P1294
Vstrekovač vysoké napätie Open - banka 2/Target nečinnosti nebol dosiahnutý
P1295
Multi-chyby - banka 1 - S Side Nízke šortky
P1296
Multi-chyby - banky 2 - S Side Nízke šortky
P1297
Vstrekovač vysokými bočnicami skratované
P1298
IDM zlyhanie
P1299
Hlavy valcov ochrana proti prehriatiu aktívnej
P1300
Kalibrácia Boost poruchy
P1301
Kalibrácia Boost Vysoká
P1302
Kalibrácia Boost Nízka
P1303
EGR Kalibrácia poruchy
P1304
EGR Kalibrácia Vysoká
P1305
EGR Kalibrácia Nízka
P1306
Kickdown nepoužijete relé Pull - V obvode proti poruchám
P1307
Kickdown nepoužijete relé Hold obvodu proti poruchám
P1308
A / C Spojka obvodu proti poruchám
P1309
Zapaľovanie Monitor AICE Chip poruchy
P1313
Zapaľovanie Hodnotiť poškodenie katalyzátora chyba - Banka 1
P1314
Zapaľovanie Hodnotiť poškodenie katalyzátora chyba - banky 2
P1315
Perzistentné zlyhať
P1316
Obvod vstrekovače / IDM kódy zistený
P1317
Obvod vstrekovače / IDM kódov, ktoré nie sú Aktualizované
P1336
Kľučky / Cam Sensor Range / výkon
P1340
Snímače polohy vačkové hriadele B obvod Závada
P1341
Snímače polohy vačkové hriadele B Range / výkon
P1345
SGC (Cam pozícia) obvodu snímača Porucha / polohy kľukového hriadeľa - vačkového hriadeľa Pozícia Korelačné
P1346
Snímač hladiny paliva B obvod Závada
P1347
Snímač hladiny paliva B Range / výkon
P1348
Snímač hladiny paliva B obvod Nízka
P1349
Snímač hladiny paliva B obvod Vysoké
P1350
Snímač hladiny paliva B Prerušovaný / bypass Line Monitor
P1351
IDM Vstupný obvod Závada / Zapaľovacia cievka riadiaceho obvodu vysokého napätia
P1352
Zapaľovacie cievky primárneho okruhu Závada
P1353
Zapaľovacie cievky B primárneho okruhu Závada
P1354
Zapaľovacie cievky C Primárny okruh Závada
P1355
Zapaľovacie cievky D primárneho okruhu Závada
P1360
Zapaľovacie cievky sekundárneho okruhu Závada
P1361
Ignition Control (IC), obvod nízkeho napätia
P1362
Zapaľovacie cievky C sekundárneho okruhu Závada
P1363
Zapaľovacie cievky D sekundárneho okruhu Závada
P1364
Zapaľovacie cievky primárneho okruhu zlyhania
P1365
Zapaľovacie cievky sekundárneho okruhu zlyhania
P1366
Náhradné zapaľovania
P1367
P1368
P1369
Teplota motora svetla Monitor zlyhania
P1370
Nedostatočná RMP Zvýšenie Počas Spark Test
P1371
Zapaľovacie cievky - Valec 1 - Predčasné Aktivácia poruchy
P1372
Zapaľovacie cievky - Valec 2 - Predčasné Aktivácia poruchy
P1373
Zapaľovacie cievky - Valec 3 - Predčasné aktivácia poruchy
P1374
Polohy kľukového hriadeľa (CKP) / Zapaľovacia cievka - valec 4 - Predčasné aktivácia poruchy
P1375
Zapaľovacie cievky - Valec 5 - Predčasné aktivácia poruchy
P1376
Zapaľovacie cievky - Valec 6 - Predčasné aktivácia poruchy
P1380
Zistilo zapaľovanie - Rough Road údaje nie sú k dispozícii
P1381
Variabilné časovanie Cam Overadvanced (Bank # 1) / zapaľovania Zistené - žiadna komunikácia s BCM
P1382
Variabilné časovanie Cam Solenoid # 1 obvod Závada
P1383
Variabilné časovanie Cam Overretarded (Bank # 1)
P1384
VVT Solenoid Závada
P1385
Variabilné časovanie Cam solenoidu B Závada
P1386
Variabilné časovanie Cam Overadvanced (Bank # 2)
P1387
Variabilné časovanie Cam Solenoid # 2 obvod Závada
P1388
Variabilné časovanie Cam Overretarded (Bank # 2)
P1389
Žiara Plug Obvod vysoké napätie nízke vstupné
P1390
Octane Nastavte Pin Out Of Self Test Range
P1391
Žiara Plug obvod nízke vstupné náklady (bankové # 1)
P1392
Žiara Plug obvodu vysokého vstupného (Bank # 1)
P1393
Žiara Plug obvod nízke vstupné náklady (bankové # 2)
P1394
Žiara Plug obvodu vysokého vstupného (Bank # 2)
P1395
Monitor Plug žiara poruchy (Bank # 1)
P1396
Monitor Plug žiara poruchy (Bank # 2)
P1397
Systém napätie Out Of Self Test Range
P1398
VVT solenoidu B obvod vysokú vstupnú
P1399
Žiara Plug obvod vysoké napätie, vysoké vstupné
P1400
DPFE Nízky vstupný obvod
P1401
DPFE obvod vysoký vstupný
P1402
EGR merania zúžené hrdlo
P1403
DPFE senzora Hadica obrátene
P1404
IAT - B obvod Závada / recirkulácie výfukových plynov v uzavretom stave výkonnosti
P1405
DPFE senzora Upstream ostriekajte alebo upchatie
P1406
Recirkulácie výfukových plynov (EGR) snímača polohy výkonu
P1407
EGR č prietoku zistený
P1408
EGR vytekať Self Test Range
P1409
EVR ovládací obvod Závada
P1411
SAI systému Nesprávne Následní prietoku zistený
P1413
SAI Sledovanie systému Nízky vstupný obvod
P1414
SAI Sledovanie systému obvode vysokú vstupnú
P1415
Vzduchové čerpadlo okruhu závada / (AIR) Systém Banka 1
P1416
Port Air okruhu závada / (AIR) systému banky 2
P1417
Port Air Reliéf obvode Závada
P1418
Split Air # 1 obvod Závada
P1419
Split Air # 2 obvod Závada
P1420
Catalyst snímača teploty Porucha
P1421
Poškodenie katalyzátora
P1422
EGI snímača teploty Porucha
P1423
EGI funkcie Test zlyhalo
P1424
EGI Žiara Plug primárne zlyhanie
P1425
EGI Žiara Plug sekundárne zlyhanie
P1426
EGI Mini - MAF Chyba Out Of Range
P1427
EGI Mini - MAF Nepodarilo skratu
P1428
EGI Mini - MAF Nepodarilo Otvorený okruh
P1429
Elektrické čerpadlo vzduch primárne zlyhanie
P1430
Elektrické čerpadlo vzduch sekundárne zlyhanie
P1433
A / C teploty chladiva obvod Nízka
P1434
A / C teploty chladiva obvod Vysoké
P1435
A / C teploty chladiva obvod Rozsah / výkon
P1436
A / C výparníka teploty vzduchu obvod Nízka
P1437
A / C výparníka teploty vzduchu obvod Vysoké
P1438
A / C výparníka teploty vzduchu obvod Rozsah / výkon
P1439
Teplota podlahy spínač obvode Závada
P1440
Odvzdušňovací ventil Stuck Open
P1441
Prchavých emisií (výparníku), systém prúdenia počas non-Purge Chevrolet iba
P1441
Prchavých emisií (výparníku), systém prúdenia počas non-Purge Oldsmobile iba
P1442
P1443
Reguláciu emisií z odparovania ventil
P1444
P1445
P1446
Vyparovaním Vac Solenoid obvod Závada
P1447
ELC systému Uzavretie ventilu prietoku poruchy
P1448
ELC System 2 porúch
P1449
Vyparovaním Skontrolujte elektromagnetický obvod Závada
P1450
Nemožno krvácať až palivovej nádrže vákuové
P1451
Výparníku Sys kontroly emisií Vent ventil okruhu
P1452
Nedá krvácať - Do vákua v nádrži
P1453
Palivová nádrž pretlakový ventil Závada
P1454
Odparovací systém Vákuové Test Závada
P1455
Výparníku Sys kontroly emisií únik zistený (Hrubý úniku / No Flow)
P1456
Palivová nádrž snímač teploty okruhu Závada
P1457
Nemožno ťahať Vákuové v nádrži
P1460
Dokorán plyn / C cutoff relé okruhu
P1461
A / C tlakový senzor napätia nízke
P1462
A / C tlakový senzor napätia vysoké
P1463
A / C Tlak senzor nedostatočný tlak Zmeniť
P1464
A / C Dopyt Mimo Self Test Range
P1465
A / C relé obvod Závada
P1466
A / C Chladivo teplotný senzor / obvod Závada
P1467
A / C Kompresor snímač teploty Závada
P1468
SSPOD otvorený okruh alebo uzatvorený okruh porúch
P1469
Nízka / C Cyklistika obdobie
P1470
A / C na bicykli príliš krátku dobu,
P1471
Elektropohonov ventilátora 1 porucha (ovládač Side)
P1472
Elektropohonov Fan 2 porucha (u spolujazdca)
P1473
Ventilátor Sekundárne vysoký ventilátor (y) vypnuté
P1474
Nízka Fan Control primárneho okruhu Závada
P1475
Relé ventilátora (Low) obvod Závada
P1476
Ventilátor relé (High) obvod Závada
P1477
Ďalšie fanúšikov relé obvod Závada
P1478
Chladiaci ventilátor ovládače poruchy
P1479
Vysoká Fan Control primárneho okruhu Závada
P1480
Ventilátor Stredná Nízka Nízka fanúšikov sa na
P1481
Ventilátor Stredná Nízka s vysokou fanúšikov na
P1482
SCP
P1483
Ak chcete výkon ventilátora obvod nadprúdu
P1484
Open Power To Pozemná VCRM
P1485
EGRV obvod Závada
P1486
EGRA obvod Závada
P1487
EGRCHK Solenoid obvod Závada
P1490
Sekundárny vzduch Reliéf solenoidu obvod Závada
P1491
Sekundárny okruh solenoidu Switch Závada
P1492
APLSOL Solenoid obvod Závada
P1493
RCNT Solenoid obvod Závada
P1494
SPCUT Solenoid obvod Závada
P1495
TCSPL Solenoid obvod Závada
P1500
P1501
Snímač rýchlosti vozidla Out Of Self Test Range
P1502
Snímač rýchlosti vozidla Prerušovaný porucha
P1503
Pomocný snímač rýchlosti poruchy
P1504
Nečinnosti Air Control obvod Závada
P1505
Nečinnosti Air Control System V adaptívne klip
P1506
Nečinnosti Air Control prekročenie rýchlosti Chyba
P1507
Nečinnosti Air Control Underspeed Chyba
P1508
Nečinnosti Control System obvod Open
P1509
Nečinnosti Control System obvod skratovaný
P1510
Nečinnosti signálu obvode Závada
P1511
Nečinnosti Switch (elektrické ovládanie škrtiacej klapky) obvod Závada
P1512
Sacom potrubí Runner Control (banka 1) Stuck Zatvorené
P1513
Sacom potrubí Runner Control (banka 2) Stuck Zatvorené
P1514
Vysoké zaťaženie Neutral / Drive Chyba
P1515
Elektrický prúd obvodu Závada
P1516
IMRC Input Error (banka 1)
P1517
IMRC Input Error (banka 2)
P1518
Sacom potrubí Runner Control (Stuck Open)
P1519
Sacom potrubí Runner Control (Stuck Zatvorené)
P1520
Sacom potrubí Runner riadiacich obvodov Závada
P1521
Variabilná sania Solenoid # 1 obvod Závada
P1522
Variabilná sania Solenoid # 2 obvod Závada
P1523
IVC Solenoid obvod Závada
P1524
Variabilná sania Solenoid systému
P1525
Air Bypass ventil systému
P1526
Air Bypass systém
P1527
Urýchliť zahrievanie Solenoid obvod Závada
P1528
Dcérske spoločnosti škrtiacej klapky elektromagnetický obvod Závada
P1529
SCAIR Solenoid obvod Závada
P1530
A / C Spojka obvod Závada
P1531
Neplatné Test - pohybom pedálu akcelerátora
P1532
IMCC obvod Závada, banka B
P1533
AAI obvod Závada
P1534
Zotrvačnosti Switch Aktívne
P1535
Ventilátorom Speed Circuit Range / výkon
P1536
Parkovacia brzda Spínač obvode zlyhania
P1537
Sacom potrubí Runner Control (banka 1) Stuck Open
P1538
Sacom potrubí Runner Control (banka 2) Stuck Open
P1539
Ak chcete výkon / C Spojka obvod nadprúdu
P1540
Vzduchu obtokový ventil okruhu Závada
P1549
P1550
PSP Out Of Self Test Range
P1565
Rýchlosť Riadenie Switch Out of Range Vysoké
P1566
Rýchlosť Riadenie Switch Out of Range Nízka
P1567
Riadenie rýchlosti výstupu obvodu
P1568
Riadenie rýchlosti schopný udržať rýchlosť
P1571
Brzdový spínač Závada
P1572
Brzda Nožný spínač obvode Závada
P1573
Polohy škrtiacej klapky nie je k dispozícii
P1574
Snímač polohy klapky Nezhody btwn senzory
P1575
Pozícia pedál Z Self Test Range
P1576
Pozícia pedál nie je k dispozícii
P1577
Snímač polohy pedála Nezhody btwn senzory
P1578
ETC napájanie menšia ako dopyt
P1579
ETC V režime obmedzenie výkonu
P1580
Elektronický plyn Monitor PCM potlačenie
P1581
Elektronický plyn Monitor Závada
P1582
Elektronická výmena dát plyn Monitor k dispozícii
P1583
Elektronický plyn Monitor Cruise Zakázať
P1584
TCU Zistené IPE obvod Závada
P1585
Riadiaca jednotka škrtiacej Závada
P1586
Škrtiace Riadiaca jednotka polohy klapky Závada
P1587
Riadiaca jednotka škrtiacej modulovaného zabezpečenia Závada
P1588
Riadiaca jednotka škrtiacej zistená strata vratnej pružiny
P1589
TCU neschopný riadiť Požadovaný uhol škrtiacej klapky
P1600
Strata KAM energie; Otvorený okruh
P1601
ECM / TCM Serial Chyba komunikácie
P1602
Imobilizér / ECM Chyba komunikácie
P1603
EEPROM Závada
P1604
Kód Word Unregestered
P1605
Keep Alive Test pamäte zlyhania
P1606
ECM Ovládanie relé O / P obvod Závada
P1607
MIL O / P obvod Závada
P1608
Vnútorné ECM Závada
P1609
Diagnostické lampy ovládače poruchy
P1610
SBDS Interaktívna kódy
P1611
P1612
P1613
P1614
P1615
P1616
P1617
P1618
P1619
P1620
P1621
Modul pre riadenie dlhodobej pamäte Performance / Slov Imobilizér zákonníka nezodpovedajú
P1622
Imobilizér ID nie je zhoda
P1623
Imobilizér kódové slovo / ID číslo napíš zlyhania
P1624
Anti Theft systému
P1625
B Dodávky VCRM fanúšikov obvod Závada
P1626
Proti krádeži pohonných hmôt Povoliť signál nie Received / B Dodávky VCRM / C obvod Závada
P1627
Modul napájacieho napätia Out Of Range
P1628
Modul zapaľovanie vstup napájania Závada
P1629
Vnútorné Voltage Regulator Závada
P1630
Vnútorné Vref Závada
P1631
Proti krádeži Štart Enable signál nie Upraviť / Hlavná relé závada (Power Hold)
P1632
Smart Alternátor Chyby senzor / obvod Závada
P1633
KAM napätie príliš nízke
P1634
Výstupné dáta Link obvod zlyhania
P1635
Pneumatika / nápravou pomer Mimo prijateľného rozsahu
P1636
Indukčné Podpis Chip Chyba komunikácie
P1637
Môže Link ECM / ABSCM obvod / Network Závada
P1638
Môže Link ECM / INSTA obvod / Network Závada
P1639
Blok ID vozidla poškodená alebo nie Programované
P1640
Powertrain DDZ dispozícii v inom module
P1641
Palivové čerpadlo primárneho okruhu zlyhania
P1642
Palivové čerpadlo Monitor obvode vysokú vstupnú
P1643
Palivové čerpadlo Monitor Nízky vstupný obvod
P1644
Palivové čerpadlo Obvod regulácia rýchlosti Závada
P1645
Palivové čerpadlo Rezistor Switch obvod Závada
P1650
PSP Switch Z Self Test Range
P1651
PSP Switch Vstupné Závada
P1652
IAC Monitor so zdravotným postihnutím do PSP Switch On Nepodarilo
P1653
Posilňovač riadenia výstupný obvod Závada
P1654
Recirkulácia Prepísať obvod Závada
P1655
Štartér Zakázať obvod Závada
P1660
Výstupný obvod Check Signal Vysoká
P1661
Výstupný obvod Check Signal Nízka
P1662
IDM_EN obvod zlyhanie
P1663
Palivá Dopyt Príkaz signálu obvode Závada
P1667
CI obvod Závada
P1668
PCM - IDM chybe komunikácie
P1670
Elektronický signál spätnej väzby nebol zistený
P1680
Dávkovacie čerpadlo oleja Závada
P1681
P1682
P1683
Dávkovacie čerpadlo oleja snímač teploty okruhu Závada
P1684
Meranie olejového čerpadla snímača polohy obvod Závada
P1685
Meranie olejového čerpadla Krokový motor okruh Závada
P1686
P1687
P1688
P1689
Kontrola tlaku oleja elektromagnetický obvod Závada
P1690
Wastegate Solenoid obvod Závada
P1691
Turbo Riadenie tlaku elektromagnetický obvod Závada
P1692
Turbo ovládanie Elektromagnetický obvod Závada
P1693
Turbo CCS obvod Závada
P1694
Turbo Poplatok Reliéf obvode Závada
P1700
Odovzdanie Neurčité Chyba (Nepodarilo sa Neutral)
P1701
Reverse Zásnubný Chyba
P1702
TRS obvod Prerušovaný porucha
P1703
Brzdové Switch Out Of Self Test Range
P1704
Digitálne TRS Nepodarilo sa Prechod štátov v KOEO / KOER
P1705
Nie v P alebo N Počas KOEO / KOER
P1706
Vysoká rýchlosť vozidla pozorovania v parku
P1707
Prevod veci Neutrálny Indikátor poruchy pevného súčasnosť
P1708
Spojka Switch obvod Závada
P1709
P1711
TFT senzor Out Of Self Test Range
P1712
Trans zníženie krútiaceho momentu Dopyt signálu Závada
P1713
TFT čidlo v rozsahu zlyhania nízkej hodnoty
P1714
SSA Indukčné Podpis Závada
P1715
SSB Indukčné Podpis Závada
P1716
SSC Indukčné Podpis Závada
P1717
SSD Indukčné Podpis Závada
P1718
TFT senzor Rozsah zlyhania Vysoké
P1720
Rýchlosť vozidla (m) obvod Závada
P1721
Rýchlosť 1 Nesprávne pomer
P1722
P1723
Rýchlosť 3 nesprávny pomer
P1724
P1725
Nedostatočná Otáčky motora sa zvyšujú počas Self Test
P1726
Nedostatočné otáčky motora klesať počas Self Test
P1727
Spojka pobreží Elektromagnetické induktívne Podpis Závada
P1728
Postúpenie sklzu Chyba
P1729
Nízke Switch 4x4 Chyba
P1730
Ovládanie prevodovky Závada 2,3,5
P1731
1-2 Shift Závada
P1732
2-3 Shift Závada
P1733
3-4 Shift Závada
P1734
P1735
Prvé Radenie okruh Závada
P1736
Druhý okruh Radenie Závada
P1737
Elektromagnetický systém väzenia
P1738
Shift time error
P1739
Sklzu Solenoid systému
P1740
Meniča krútiaceho momentu spojky Indukčné Podpis Závada
P1741
Meniča krútiaceho momentu ovládanie spojky Chyba
P1742
Meniča krútiaceho momentu spojky Solenoid prepadol na
P1743
Meniča krútiaceho momentu spojky Solenoid Failied Na
P1744
Meniča krútiaceho momentu spojky výkon systému
P1745
Tlak v potrubí Solenoid systéme
P1746
Ovládacie tlak solenoidu "A" Otvorený okruh
P1747
Ovládacie tlak solenoidu "A" Short Circuit
P1748
EPC Závada
P1749
Ovládací tlak solenoidu Nepodarilo Nízka
P1751
Shift Solenoid výkon
P1754
Spojka pobreží Solenoid obvod Závada
P1755
Intermediate Snímač rýchlosti (ISS) Porucha
P1756
P1760
P1761
P1762
Overdrive Band Nepodarilo vypnuté
P1765
Načasovanie Solenoid obvod Závada
P1767
Meniča krútiaceho momentu spojky obvod Závada
P1768
Výkon / Normálny / Zimný režim Vstupné Závada
P1769
AG4 Prenos krútiaceho momentu modulácie poruchy
P1770
Spojka Solenoid obvod Závada
P1775
Prenosových sústav MIL porúch
P1776
Zapaľovanie Retard Žiadosť Doba trvania poruchy
P1777
Zapaľovanie Retard Žiadosť obvodu proti poruchám
P1778
Postúpenie Reverzné I / P obvod Závada
P1779
TCIL obvod Závada
P1780
Trans kontrolu Switch (O / D Zrušiť) Z Self Test Range
P1781
4X4 Switch Z Self Test Range
P1782
P / ES obvod Out Of Self Test Range
P1783
Prevodovka Stav prehriatiu
P1784
Prevodovka mechanická porucha - Prvý a reverzné
P1785
Prevodovka mechanická porucha - Prvý a druhý
P1786
3-2 podradenie Chyba
P1787
2-1 podradenie Chyba
P1788
Ovládacie tlak solenoidu "B" Otvorený okruh
P1789
Ovládacie tlak solenoidu "B" Short Circuit
P1790
TP (mechanické) obvod Závada
P1791
TP (Electric) obvod Závada
P1792
Barometer Tlak okruhu Závada
P1793
Nasávaného vzduchu Objem obvod Závada
P1794
Napätie batérie obvod Závada
P1795
Nečinnosti Switch obvod Závada
P1796
Kick nadol Switch obvod Závada
P1797
Neutrálny Switch obvod Závada
P1798
Teploty chladiacej kvapaliny obvod Závada
P1799
Hold Switch obvod Závada
P1800
Prevodovka Spojka blokovanie bezpečnostný spínač obvode zlyhania
P1801
Prevodovka Spojka blokovanie bezpečnostný spínač Otvorený okruh
P1802
Prevodovka Spojka blokovanie bezpečnostný spínač skrat na batérie
P1803
Prevodovka Spojka blokovanie bezpečnostný spínač skrat na zem
P1804
Prevodovka 4-Wheel Drive Vysoké Ukazovateľ obvod zlyhania
P1805
Prevodovka 4-Wheel Drive Vysoké Ukazovateľ Otvorený okruh
P1806
Prevodovka 4-Wheel Drive Vysoké Ukazovateľ skrat na batérie
P1807
Prevodovka 4-Wheel Drive Vysoké Ukazovateľ skrat na zem
P1808
Prevodovka 4-Wheel Drive Nízke indikátor Chyba obvodu
P1809
Prevodovka 4-Wheel Drive Nízke Ukazovateľ Otvorený okruh
P1810
TFP polohu ventilu Switch obvod / Prevodovka 4-Wheel Drive Nízke Ukazovateľ skrat na batérie
P1811
Prevodovka 4-Wheel Drive Nízke Ukazovateľ skrat na zem
P1812
Prevodovka 4-Wheel Drive móde Vybrať obvod zlyhania
P1813
Prevodovka 4-Wheel Drive Voľba režimu Otvorený okruh
P1814
Prevodovka 4-Wheel Drive Vybrať režim skrat na batérie
P1815
Prevodovka 4-Wheel Drive Vybrať režim skrat na zem
P1816
Postúpenie bezpečnostný spínač neutrálnej polohy obvod zlyhania
P1817
Postúpenie bezpečnostný spínač neutrálnej polohy Otvorený okruh
P1818
Postúpenie bezpečnostný spínač neutrálnej polohy skratu na batérie
P1819
Postúpenie bezpečnostný spínač neutrálnej polohy skrat na zem
P1820
Postúpenie Prenos zo smeru hodinových ručičiek Shift cievku relé obvod zlyhania
P1821
Postúpenie Prenos zo smeru hodinových ručičiek Shift cievku relé Otvorený okruh
P1822
Postúpenie Prenos zo smeru hodinových ručičiek Shift cievku relé skrat na batérie
P1823
Postúpenie Prenos zo smeru hodinových ručičiek Shift cievku relé skrat na zem
P1824
Prevodovka 4-Wheel Drive Spojka relé obvod zlyhania
P1825
Prevodovka 4-Wheel Drive Spojka relé Otvorený okruh
P1826
Prevodovka 4-Wheel Drive Nízke Spojka relé obvod batérie
P1827
Prevodovka 4-Wheel Drive Nízke Spojka relé obvode Svetlá
P1828
Postúpenie prípade odovzdania proti smeru hodinových ručičiek Shift cievku relé obvod zlyhania
P1829
Postúpenie prípade odovzdania proti smeru hodinových ručičiek Shift cievku relé Otvorený okruh
P1830
Postúpenie prípade odovzdania proti smeru hodinových ručičiek Shift cievku relé skrat na batérie
P1831
Postúpenie prípade odovzdania proti smeru hodinových ručičiek Shift cievku relé skrat na zem
P1832
Postúpenie prípade odovzdania uzávierka diferenciálu-Up elektromagnetický obvod zlyhania
P1833
Postúpenie prípade odovzdania uzávierka diferenciálu-Up Solenoid Otvorený okruh
P1834
Postúpenie prípade odovzdania uzávierka diferenciálu-Up elektromagnetický skrat na batérie
P1835
Postúpenie prípade odovzdania uzávierka diferenciálu-Up elektromagnetický skrat na zem
P1836
Postúpenie prípade odovzdania predný snímač otáčok hriadeľa obvod zlyhania
P1837
Postúpenie Prenos zo zadnej hriadeľa snímač otáčok obvod zlyhania
P1838
Postúpenie prípade odovzdania Shift Motor okruh zlyhania
P1839
Postúpenie prípade odovzdania Shift Motor Otvorený okruh
P1840
Postúpenie prípade odovzdania Shift Motor skrat na batérie
P1841
Postúpenie prípade odovzdania Shift Motor skrat na zem
P1842
Postúpenie prípade odovzdania uzávierka diferenciálu-Up Feedback Switch obvod zlyhania
P1843
Postúpenie prípade odovzdania uzávierka diferenciálu-Up Feedback Switch Otvorený okruh
P1844
Postúpenie prípade odovzdania uzávierka diferenciálu-Up Feedback Switch skrat na batérie
P1845
Postúpenie prípade odovzdania uzávierka diferenciálu-Up Feedback Switch skrat na zem
P1846
Postúpenie prípade odovzdania Kontakt doska''Chyba obvodu
P1847
Postúpenie prípade odovzdania Kontakt doska''Otvorený okruh
P1848
Postúpenie prípade odovzdania Kontakt doska''skrat na batérie
P1849
Postúpenie prípade odovzdania Kontakt doska''skrat na zem
P1850
Postúpenie prípade odovzdania Kontakt doska 'B' Chyba obvodu
P1851
Postúpenie prípade odovzdania Kontakt doska 'B' Otvorený okruh
P1852
Postúpenie prípade odovzdania Kontakt doska 'B' skrat na batérie
P1853
Postúpenie prípade odovzdania Kontakt doska 'B' skrat na zem
P1854
Postúpenie prípade odovzdania Kontakt doska 'C' Chyba obvodu
P1855
Postúpenie prípade odovzdania Kontakt doska 'C' Otvorený okruh
P1856
Postúpenie prípade odovzdania Kontakt doska 'C' skrat na batérie
P1857
Postúpenie prípade odovzdania Kontakt doska 'C' skrat na zem
P1858
Postúpenie prípade odovzdania Kontakt doska 'D' Chyba obvodu
P1859
Postúpenie prípade odovzdania Kontakt doska 'D' Otvorený okruh
P1860
TCC PWM Elektromagnetický obvod Elektrický / vysielanie prenosov zo Spoj doska 'D' skrat na batérie
P1861
Postúpenie prípade odovzdania Kontakt doska 'D' skrat na zem
P1862
Postúpenie prípade odovzdania Kontakt doska napájania obvodu zlyhania
P1863
Postúpenie prípade odovzdania Kontakt doska napájania Otvorený okruh
P1864
Postúpenie prípade odovzdania Kontakt doska napájania krátka na batérie
P1865
Postúpenie prípade odovzdania Kontakt doska napájania krátka na pozemných
P1866
Postúpenie prípade odovzdania systému Concern - Servis povinná
P1867
Postúpenie prípade odovzdania Kontakt doska Všeobecnej obvod zlyhania
P1868
Prevodovka automatická 4-Wheel Drive Indicator (Lamp) obvod Zlyhanie
P1869
Prevodovka automatická 4-Wheel Drive Indicator (Lamp) obvod krátka na batérie
P1870
Postúpenie komponentov pošmyknutia / Prevodovka Mechanická Transfer veci 4x4 Switch obvod zlyhania
P1871
Prevodovka Mechanická Transfer veci 4x4 Switch obvod krátka na batérie
P1872
Prevodovka Mechanická 4-Wheel Drive uzáverou lampa obvod zlyhania
P1873
Prevodovka Mechanická 4-Wheel Drive uzáverou lampa obvod krátka na batérie
P1874
Prevodovka Automatická Hallovho sonda napájanie obvodu zlyhania
P1875
Prevodovka Automatická Hallovho sonda napájací obvod krátka na batérie / 4WD Low Switch obvode Elektrické
P1876
Postúpenie Transfer Prípad 2-Wheel Drive Solenoid obvod zlyhania
P1877
Postúpenie Transfer Prípad 2-Wheel Drive Elektromagnetický obvod krátka na batérie
P1878
Postúpenie prípade odovzdania spojke elektromagnetický obvod zlyhania
P1879
Postúpenie prípade odovzdania spojke Solenoid Otvorený okruh
P1880
Postúpenie prípade odovzdania spojke Solenoid Krátke na batérie
P1881
Chladiacej kvapaliny motora spínača hladiny obvod zlyhania, GEM
P1882
Chladiacej kvapaliny motora spínača hladiny obvod Krátke na pozemných
P1883
P1884
Chladiacej kvapaliny motora Úroveň lampa obvod Krátke na pozemných
P1885
Postúpenie prípade odovzdania spojke Solenoid Krátke na pozemných
P1886
4X4 inicializácia zlyhala
P1890
Postúpenie 4WD Vybrať režim Návrat Vstupný obvod zlyhania
P1891
Postúpenie prípade odovzdania Kontakt doska Svetlá Späť Otvorený okruh
P1900
OSS obvod Prerušovaný porucha
P1901
TSS obvod Prerušovaný porucha
P1902
Ovládacie tlak solenoidu "B" Občasné krátke
P1903
Ovládacie tlak solenoidu "C" Short Circuit
P1904
Ovládacie tlak solenoidu "C" Otvorený okruh
P1905
Ovládacie tlak solenoidu "C" Občasné krátke
P1906
Kickdown nepoužijete Vytiahnite relé Otvoriť alebo skrat na zem
P1907
Kickdown nepoužijete Hold relé Otvoriť alebo skrat na zem
P1908
Prenos tlakového okruhu solenoidu Otvoriť alebo krátke na pozemných
P1909
Trans teplotný snímač obvodu Open alebo skratovaný na PWR alebo GND
P1910
VFS výstup tlaku Nepodarilo Nízka
P1911
VFS B výstup tlaku Nepodarilo Nízka
P1912
VFS C výstup tlaku Nepodarilo Nízka
P1913
Tlakový spínač obvodu Závada
P1914
Ručne posunuté Automatické (MSA) SW obvod Malfa
P1915
Spínač spätného chodu obvode Závada
P1916
Vysoká spojkový bubon snímač otáčok Závada
P1917
Vysoká spojkový bubon snímač otáčok Prerušovaný
P1918
Postúpenie Rozsah displeja obvod Závada
