DOKÁZAL BY MI NĚKDO PORADIT S TÍMTO PROBLÉMEM.JEDNÁ SE O DUCATO RV.2002,2.0 JTD,TYP MOT.RHV
CHYBA SE VYSKYTUJE HLAVNĚ PŘI JÍZDĚ NA TROJKU PŘI ZÁTAHU MOTORU A VYTOČENÍ NA CCA 3.5TIS SE NAJEDNOU VYPNE MOTOR A ROZSVÍTÍ SE KONTROLKY.POKUD HNED ZAČNU STARTOVAT AK SE NIC NEDĚJE,NECHYTNE ALE KDYŽ POČKÁM TAK 5 VTEŘIN,ZAPNU ZAPALOVÁNÍ TAK UŽ MOTOR NASKOČÍ A JEDE OPĚT BEZ PROBLÉMŮ AŽ ZASE DO TOHO ZÁTAHU NA TROJKU NEBO I NA DVOJKU.
DĚKUJI VŠEM ZA POMOC.
DUCATO 2.0 JTD ZHASÍNÁ MOTOR
